What head gasket does the JDM D15b vtec use?
Old Apr 12, 2005 | 10:16 AM
Mattmob's Avatar
From: Where we rock teh dookies, Nor Cal, You Es of EY
Default What head gasket does the JDM D15b vtec use?
anyone?
Thanks in advance
Old Apr 12, 2005 | 10:19 AM
TrackSpeedRacing's Avatar
Default Re: What head gasket does the JDM D15b vtec use? (Mattmob)
The d16z6 head gasket should work fine.
Old Nov 8, 2006 | 01:23 PM
iphatcrxi's Avatar
Default Re: What head gasket does the JDM D15b vtec use? (TrackSpeedRacing)
will the d16y8 work and will it bump the cr?
Old Nov 8, 2006 | 01:31 PM
SOHCejcivic's Avatar
Default Re: What head gasket does the JDM D15b vtec use? (iphatcrxi)
^^slightly. d15bs use all the same parts (for the most part) as a z6 if i'm not mistaken.
Old Nov 8, 2006 | 01:35 PM
iphatcrxi's Avatar
Default Re: What head gasket does the JDM D15b vtec use? (SOHCejcivic)
so would it be in my best interest to get a d16y8 gasket?
Old Nov 8, 2006 | 04:46 PM
iphatcrxi's Avatar
Old Nov 8, 2006 | 04:51 PM
92_VX_EG's Avatar
Are you sure. I used a Z6 headgasket on my D15Z1 and it overheated on the highway after I put the headgasket on. I've heard that the D15B's use a lot of the same components as a D15Z1 also.
Old Nov 8, 2006 | 04:52 PM
92ehatch's Avatar
y8 headgasket is cheaper than the z6 gasket at most dealerships i think
so yes i would go with the y8.
they are basically the same thing, but the y8 has a coupel poinless tabs on it
Old Nov 8, 2006 | 04:53 PM
iphatcrxi's Avatar
Default Re: What head gasket does the JDM D15b vtec use? (92ehatch)
yea i think D15b are jsut D15Z1 with D16z6 head.
lilsicsoul
Mar 11, 2009 04:21 PM
austincrx
Jun 2, 2007 02:00 PM
sinfulj32
Nov 29, 2005 06:54 AM
lonefuzzy79
Dec 7, 2002 08:33 PM
93delsol
Dec 21, 2001 12:06 PM
