87 Accord shakes when I turn it off.
Old Apr 12, 2005 | 09:09 AM
JDM-EJ1's Avatar
Default 87 Accord shakes when I turn it off.
Everyonce in a while when I turn off my Accord it'll shake for a couple seconds when I turn it off. And then when I goto start it it'll have a really hard time starting. But once it's started, it'll run fine.
Now, it doesn't shake ALL the time when I turn it off, every once in a while though. What could it be?
Old Apr 12, 2005 | 09:21 AM
Vanilla Sky's Avatar
this condition is called dieseling... in your case, i'm willing to bet it only does it on a hot day or after a long or hard drive... if that's the case, replace your thermostat and flush your coolant system
Old Apr 12, 2005 | 09:37 AM
JDM-EJ1's Avatar
Default Re: (Vanilla Sky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vanilla Sky &raquo;</TD></TR><TR><TD CLASS="quote">this condition is called dieseling... in your case, i'm willing to bet it only does it on a hot day or after a long or hard drive... if that's the case, replace your thermostat and flush your coolant system</TD></TR></TABLE>
Not really, I live in Washington yesterday I went to the grochery store (I hadn't driven the car for like 6 hours). I started it up, and drove to the grochery store, it was average temprated outside mid 50's I'm guessing. When I got to the grochery store, I turned it off and it shook, when I started it, it wouldn't want to start I had to pump the gas repeatidly.
When I got home, I turned it off didn't shake I then started it again and it started fine.
This morning when I went to lunch I hadn't driven the car for like 4 hours, I got to McDonalds, I turned it off, it shook again, I started it, but it didn't want to start but I got it started. When I got back to work, I turned it off and it was normal.
Old Apr 12, 2005 | 09:40 AM
Desslok's Avatar
Default Re: (JDM-EJ1)
Check your timing. I have seen this caused by the timing being too far off(I think advanced?). I'm sure there are other causes as well, such as carbon deposits, etc. But I would make sure your timing is set right, then try a fuel system cleaner.
Old Apr 12, 2005 | 09:41 AM
JDM-EJ1's Avatar
Default Re: (Desslok)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Desslok &raquo;</TD></TR><TR><TD CLASS="quote">Check your timing. I have seen this caused by the timing being too far off(I think advanced?). I'm sure there are other causes as well, such as carbon deposits, etc. But I would make sure your timing is set right, then try a fuel system cleaner.</TD></TR></TABLE>
Could this seriously mess up my car? Like cause it not to work?
Old Apr 12, 2005 | 10:04 AM
Desslok's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-EJ1 &raquo;</TD></TR><TR><TD CLASS="quote">
Could this seriously mess up my car? Like cause it not to work?</TD></TR></TABLE>
It could if it's detonating. Does it ping/knock when you are driving? When was the last time you had it tuned up?
Old Apr 12, 2005 | 10:15 AM
JDM-EJ1's Avatar
I don't hear a pinging or knocking of any sorts, but honestly I have a leak in my exhaust so I don't think I could hear it that well. I bought it about 3 months ago and I haven't gotton it tuned up yet.
Old Apr 12, 2005 | 05:34 PM
go ahead and tune it up... cap and rotor, plugs, plug wires, and air filter...
BTW, what trimline is your car?
Old Apr 12, 2005 | 08:09 PM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vanilla Sky &raquo;</TD></TR><TR><TD CLASS="quote">go ahead and tune it up... cap and rotor, plugs, plug wires, and air filter...
BTW, what trimline is your car?</TD></TR></TABLE>
Yeah, definitely. Oh, sorry it's a 4 door LX.
Old Apr 15, 2005 | 09:16 AM
deserthonda's Avatar
could have too high an idle . whe the car idles is it aroune 750-???
kidcool1977
Aug 29, 2009 10:22 AM
CivicSD
Jul 27, 2007 03:52 AM
95white
Feb 9, 2007 03:36 PM
stevescivic
Jul 30, 2004 04:10 PM
92KillerBee
Sep 2, 2003 08:53 AM
