MAP SENSOR??
Old Apr 12, 2005 | 08:38 AM
mr. vang's Avatar
Default MAP SENSOR??
okay there two plugs on the fire wall map sensor..i current using the bigger plug for the tb mount map. what do i do with the smaller plug..thanks..
Old Apr 12, 2005 | 09:02 AM
mr. vang's Avatar
Default Re: MAP SENSOR?? (jdm_whore)
ttt
Old Apr 12, 2005 | 10:09 AM
DocSean's Avatar
I'd also like to know...I suppose we could probably do a search.
Old Apr 12, 2005 | 11:10 AM
mr. vang's Avatar
Default Re: (spankjelly)
i did..nothing came up..all i found was to use the big plug for the map but nothing else for the little two wire plug..
Old Apr 12, 2005 | 11:21 AM
mr. vang's Avatar
Default Re: (jdm_whore)
tttt
Old Apr 12, 2005 | 02:07 PM
vegaskurt's Avatar
Just want to bump this, I did not find anything in the search. I got a y8 tb that i want to use at some point.
Old Apr 12, 2005 | 02:09 PM
CRX_Control's Avatar
Default Re: (vegaskurt)
just leave the other plug alone which is what i did and it didnt seem to bother my y8
Old Apr 12, 2005 | 02:17 PM
Outsane's Avatar
Default Re: (CRX_Control)
can you take a pic so I can understand better
Old Apr 13, 2005 | 04:21 PM
mr. vang's Avatar
Default Re: (Outsane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outsane &raquo;</TD></TR><TR><TD CLASS="quote">can you take a pic so I can understand better</TD></TR></TABLE>
sorrie camera got busted..its the little two wire plug that plugs into the firewall mapsesor..can i just leave it unplug like that.
Old Apr 13, 2005 | 07:41 PM
doublethink's Avatar
swap with a newer manifold?
whats going on?
::uses magic ESP ability::
look up the helms man. it will tell you where those wires go.
http://tech.hybridgarage.com/t...l.pdf
Old Apr 14, 2005 | 07:37 PM
Outsane's Avatar
Default Re: MAP SENSOR?? (doublethink)
Are you running obd1 or 0?
Old Apr 14, 2005 | 09:21 PM
B20Monster's Avatar
Default Re: MAP SENSOR?? (Outsane)
the 2 wire plug is for the evap canister purge solenoid. it wont throw any codes if unplugged.. its just used for smog purposes and to relieve some pressure in the fuel system. it would make it easier if you told us what manifold you are using.
spidermancivic
May 27, 2005 10:19 AM
JDMlyfestyle
Oct 17, 2004 05:27 PM
ebp 99 si
Jun 1, 2004 11:44 AM
*Boostwerks*
May 9, 2004 01:30 AM
pissedoffsol
Dec 5, 2003 04:58 PM
