gas smell inside
Old Apr 12, 2005 | 08:00 AM
TealCivic93's Avatar
Default gas smell inside
I just bought a 1990 Honda Civic Si. It had a blown Si motor. I took my d15b from my 93 dx, put on the intake, headers,and tranny from the Si. It has an idle problem at idle but that will be fixed when I change the AIC control valve and the throttle body. Anyways, I seem to get a gas smell when I take off in first and second..... and I don't know where it could be coming from.. any ideas?
Thanks
JF
Old Apr 12, 2005 | 09:00 AM
LShatchie's Avatar
Default Re: gas smell inside (TealCivic93)
Try looking around in the engine bay, it could be your intake manifold gasket leaking.
Old Apr 13, 2005 | 05:58 AM
i found out I have a hole in my cat.......
Old Apr 14, 2005 | 05:15 AM
it only smells when I open the sunroof or the windows. when they are closed i dont smell anything. What could it be?
Old Apr 14, 2005 | 05:48 AM
MtnCRX's Avatar
Default Re: (TealCivic93)
could be your car is going to explode any second now. How old is your fuel filter?
Old Apr 14, 2005 | 05:51 AM
explode? i dont know i just bought the car. Where is the fuel filter located? thanks
Old Apr 14, 2005 | 06:29 AM
MtnCRX's Avatar
i was kidding about the explode thing.... the fuel filter is against the firewall, under the hood, on the passenger side. im sure someone has a pic they can post for you...
Old Apr 14, 2005 | 07:21 AM
ok thanks. anyone have a pic?
Old Apr 14, 2005 | 09:47 AM
travissmithoh's Avatar
Old Apr 14, 2005 | 09:51 AM
RACINTWEEK's Avatar
Default Re: (travissmithoh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by travissmithoh &raquo;</TD></TR><TR><TD CLASS="quote"> feul filter </TD></TR></TABLE>
Old Apr 14, 2005 | 05:12 PM
ok thanks so with time if you dont change it what can happen? do you think thats where the gas smell is coming from?
Old Apr 14, 2005 | 05:44 PM
bagpipe goatee's Avatar
smell could be coming from a loose fitting under the hood or a leky tank. they tend to rust out on the seam on the side.
Old Apr 14, 2005 | 05:49 PM
4drEF's Avatar
Keyboard Humorist
Does it have the charcoal canister in place?
Without that, the fumes from the purge solenion/EVAP system go to open air if the hoses weren't plugged properly.
Old Apr 14, 2005 | 06:05 PM
sinneD's Avatar
I would check out the gas tank for rust holes... get under there and see if you can smell a strong odor. I would fill the tank up and then jack up the front of your car only... when i've had rusty tanks this forced the leak because of gravity. Also, sniff around your rear seat to see if a gas odor is coming in from under that. That could be why you smell it when the sunroof is open... its creates sort of a vacuum and could pull the odor in. I had the same problem with the windows open in mine.. it was the tank. You can get one at auto zone.
Anyway, if that isnt the cause, check the fuel filter like stated.
Old Apr 14, 2005 | 09:05 PM
pisetup's Avatar
I too have a problem like this. But it's not gas I smell, it smells of exhaust. Any ideas?
Old Apr 14, 2005 | 09:33 PM
Jeff's Avatar
Banned
It can't be as bad as me. I got a hole in my gas tank. Can't put more then 5$ gas in at a time. Hopefully a CRX gas tank fits on.
Old Apr 14, 2005 | 10:13 PM
31flavorscivic's Avatar
Default Re: (Jeff)
I call for it being the hole in the cat. I just swapped my ZC in and I know my exhaust is leaking in 2 places, but it smells like gas, even though im not running rich or leaking (getting 24+ MPG).
Just get that cat fixed and I almost promise it'll go away. Gas and exhaust smell almost the same from inside the car.
Old Apr 15, 2005 | 04:43 AM
Default Re: (31flavorscivic)
ok thanks
Old Apr 15, 2005 | 05:28 AM
tallguy's Avatar
I had the same thing and it turned out to be a broken injector O ring.
Old Apr 16, 2005 | 06:18 PM
where is the broken injector O ring located?
Old Apr 17, 2005 | 08:57 AM
MtnCRX's Avatar
why, the injector of course
BIGef
18
Jan 18, 2013 05:52 AM
SiMateoAko
11
Feb 23, 2006 08:23 AM
BlendedEJ8
Jan 31, 2005 10:44 PM
machine4321
May 26, 2004 04:10 PM
duppykiller1
Mar 21, 2003 04:36 PM
