2nd gen in 98 dx hatch help
Old Apr 12, 2005 | 12:44 AM
RedRocket00's Avatar
Default 2nd gen in 98 dx hatch help
ok so heres the deal I have a 98 dx hatch, i just got a 2nd gen b16, so i have the mtr, trans, etc everything to bolt in and start, well i am having a few problems, the DX harness goes straight to the ECU there is no plug to disconnect, so i was told to use the DX harness and get a jumper for the ECU to fit, well i tried that, and its working out great but there arent enough plugs on the DX harness to match the b16 motor, I know i will need to get the VTEC wired, but there are still sensors that will need to be plugged in, but there is no plug for them, another problem i am having is the back T bracket, i was told to use the stock DX upper mounts which fit perfectly on the B swap, but to buy a 99-00 si rear bracket, well its too long, i need it to be shorter what can I do? and finally which kind of throttle cable bracket will i need to buy, and what injectors will i need, the DX harness will not match the fuel injectors that are with the motor, and i cannot use the harness that came with the motor because there isnt any harness from the motor to the ECU since the DX harness goes straight to the ECU, any help will do people thanks!!!
Old Apr 12, 2005 | 07:16 PM
Default Re: 2nd gen in 98 dx hatch help (RedRocket00)
anyone??
JDMforlifeOH
Aug 10, 2016 07:44 AM
89cpe
Oct 26, 2007 12:49 PM
lilred92hatch
Mar 12, 2003 03:54 PM
