rear engine mount bracket stress
Old Apr 11, 2005 | 11:46 PM
biassj's Avatar
Default rear engine mount bracket stress
Here's the thing, had the two lower bolts that connected to the transmission broken and tooked a piece of my transmission case. I also didn't have the top bolt connected because my block was damage, and there's no hole for the bolt. It's probably what caused the problem. So was wondering if there's a way to reduce the stress added to the rear engine mount bracket for the future? I'm going to try to fix the block, so I can have all three bolts connected to the bracket.
Mounts:
Old Apr 12, 2005 | 04:24 AM
zman's Avatar
Default Re: rear engine mount bracket stress (biassj)
are you serious? I had the same thing happen to me...well kinda. The shop who did my swap used the wrong rear mount and only 2 of the 3 bolts that hold the tranny to the mount were used. So the middle bolt on the tranny side of the mount took a chunk of the casing out, the bolt is still fine, but i think the picture speaks for itself.
What do you plan on doing about the chunk in your tranny casing?
Old Apr 12, 2005 | 10:05 AM
biassj's Avatar
Default Re: rear engine mount bracket stress (zman)
Buy a new transmission,
Old Apr 12, 2005 | 07:43 PM
biassj's Avatar
Any ideas?
Old Apr 13, 2005 | 07:04 AM
mmuller's Avatar
Mad Scientist
weld and tap
mateo5046
Apr 14, 2008 01:04 PM
c0d0r
11
Jan 29, 2008 12:00 PM
e jay one
12
Nov 3, 2006 07:16 AM
vtechrex
May 26, 2006 01:39 PM
8ball629
May 5, 2004 10:40 AM
