d16z6 block, d16a6 tranny, what clutch?
Old Apr 11, 2005 | 10:25 PM
othick's Avatar
Default d16z6 block, d16a6 tranny, what clutch?
I'm replacing the engine in my 91 civic si with a d16z6. I'm wondering if I can use the z6 flywheel and clutch or if I have to use the a6 flyweel and clutch or a combination of the two. Thanks.
Old Apr 11, 2005 | 10:33 PM
4drmadness's Avatar
I think that it would be the Z6 combo but I could be wrong and would learn something if not...
Old Apr 12, 2005 | 04:30 AM
91civicDXdude's Avatar
any will work. as far as clutches, you can use either 88-91 Si d16a6 or 92-95 EX/Si d16z6. the clutch, pressure plate, and pilot bearing are identical, the only difference lies in the throwout bearing. a 92-95 hydro tranny throw out bearing will not work with cable tranny.
Old Apr 12, 2005 | 09:40 AM
othick's Avatar
Thanks for the help, I'll pick up the new throwout bearing.
Old Apr 12, 2005 | 06:11 PM
blackeg's Avatar
Default Re: (othick)
use the z6 clutch and flywheel, it works fine. right now im running a z6 motor with a z6 flywheel and a 97 hx clutch and pp with my 91 cable tranny
Old Apr 14, 2005 | 05:34 AM
RACINTWEEK's Avatar
Default Re: (blackeg)
diff combos may work, but its a good rule of thumb to match you clutch,pp,flywheel to you trans
Old Apr 14, 2005 | 06:12 AM
tgreaves's Avatar
Default Re: (RACINTWEEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACINTWEEK &raquo;</TD></TR><TR><TD CLASS="quote">diff combos may work, but its a good rule of thumb to match you clutch,pp,flywheel to you trans</TD></TR></TABLE>
All the 90-00 flywheels are the same..
I would look into either a Clutchmasters clutch or Exedy ceramametallic clutch..
pinecone
Jun 22, 2006 05:27 PM
grrrrrr4me
Mar 18, 2005 01:46 PM
I Gotta Question
Jan 2, 2004 03:35 PM
hybrid_eg
Feb 19, 2003 08:04 AM
DsMWookie
Sep 18, 2002 09:49 PM
