Swap Help
Old Apr 11, 2005 | 09:35 PM
AsianInvasionKP's Avatar
Default Swap Help
Never done a swap before and i've researched a little bit but i still need some major "clear" info on the swap i'm trying 2 perform
I have a 1990 Honda Civic LX 4DR sedan, the engine i want to swap into it is a B16B OBD2a
If i buy this motor from totaljdm.com it comes with:
Items Included with the Swap:
5-Speed Manual Hydraulic Transmission
Engine Control Unit (ECU)
Distributor
Intake Manifold
Exhaust Manifold
Alternator
Air Conditioning Pump
Power Steering Pump
Vtec Solenoid
Half Shaft (Intermediate Shaft)
Available Options (if in-stock):
Axles: $75.00USD
Shift Linkage: $70.00USD
Now after i purchase this motor, what more do i need to get it running, and what problems will i encounter with trying to perform this swap. As i said previously i have no clue how different gen motors work with older gen cars.
Thanks
Steve
Old Apr 12, 2005 | 07:30 AM
bump
Old Apr 12, 2005 | 08:00 AM
Ronin150's Avatar
Default Re: (AsianInvasionKP)
Don't forget motor mounts. Have to get the cable to hydro conversion ones.
I'm not sure if the lx has the resistor box for you injectors, so you might want to look into that also.
Hope that helps out some.
Old Apr 12, 2005 | 09:18 AM
CRXVTEC69's Avatar
Default Re: Swap Help (AsianInvasionKP)
http://www.speed-garage.com
Old Apr 12, 2005 | 11:19 AM
Default Re: (Ronin150)
Alright thanx for the info i know about mounts and cable conversion. i'm mainly looking for wiring conversion and if anyone else has done this swap
steve
Old Apr 12, 2005 | 11:25 AM
Ronin150's Avatar
I see ryanwire.com (I think that's the name of the person that does the wiring harnesses) around alot. Look for that member, they could help you with the wiring harness issue.
Old Apr 12, 2005 | 11:30 AM
manson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ronin150 &raquo;</TD></TR><TR><TD CLASS="quote">I see ryanwire.com (I think that's the name of the person that does the wiring harnesses) around alot. Look for that member, they could help you with the wiring harness issue.</TD></TR></TABLE>
pretty sure its http://www.rywire.com
Old Apr 12, 2005 | 11:32 AM
Ronin150's Avatar
Default Re: (manson)
I had just found it and was about to post that up. Thanks for backing me up.
Old Apr 12, 2005 | 02:06 PM
thanx for the tip, has anyone ever heard of anyone doing this swap b4 or seen it? i could use some advice from someone semi experienced, not that the info i have gotten isn't.
EJ8Bramaged
Honda Civic (2001 - 2005)
24
Dec 21, 2015 01:36 PM
landon2992
Jul 26, 2010 12:26 PM
pipes70
Feb 12, 2006 07:10 PM
tltas0325
Apr 13, 2004 08:21 PM
