Tranny Poblem?
For some odd reason my transmission is having a problem going in gear. I noticed tonight with the tranny in neutral that when i press my clutch in that the car idles around 900 and when i let go of the clutch it seems as if the clutch is grabbing and the car boggs down. I can actually hear the clutch grab when i let go of the clutch even though im not in gear. What could this be? It wont let me put the car in gear when i come to a complete stop.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">It could be that the clutch is not disengaging all the way. Bleed the slave cylinder and see if it helps it any.</TD></TR></TABLE>
correct. also if your clutch is starting to go then most likely the springs on the clutch are shot.
