Tranny Fluid Mixture for this summer. Check out my mixture!!!
Old Apr 11, 2005 | 07:56 PM
92-LS-Civic's Avatar
Default Tranny Fluid Mixture for this summer. Check out my mixture!!!
OK, i was referred by a friend to use this. His back ground is that he owns his own shop, he has built alot of hondas up, and is very good at what he does. He recommended me to use this mixture. Just wondering what you thought and now maybe you can try it. He say to go out and by a quart of each of the following....10-30, 20-50, and Lucus Oil. What do you guys think of the mixture? He didnt specify which brand, but i bought mobil 1 oil. thanks if you want post what you use.
Old Apr 11, 2005 | 08:56 PM
drdisco69's Avatar
Default Re: Tranny Fluid Mixture for this summer. Check out my mixture!!! (zdowell17)
I sure as hell don't use Lucas:
http://www.bobistheoilguy.com/...s.htm
Why are we mixing things? What is wrong with Honda MTF or some of the other popular fluids people are using?
Old Apr 12, 2005 | 04:32 AM
91civicDXdude's Avatar
straight 10w-30 non synthetic
Old Apr 12, 2005 | 06:43 AM
Honda Hick's Avatar
On my '90 Integra I had 251k miles on it and the bearings and gears had some pretty good wear on them. I tried 10w-30 with some Lucas oil and it did shift better and not make as much noise. Then I tried Honda MTL and it was a crapload better. It shifted even better and when cold it was alot easier to get into gear because the MTL is actually very thin compared to oil and Lucas. I'd def recommend the MTL, good stuff.
Old Apr 12, 2005 | 08:22 AM
Default Re: Tranny Fluid Mixture for this summer. Check out my mixture!!! (Honda Hick)
that is what i have in my car actually right now. He only drives his car in the summer. any body else have a opioion?
Old Apr 12, 2005 | 08:30 AM
jweller's Avatar
Default Re: Tranny Fluid Mixture for this summer. Check out my mixture!!! (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">I sure as hell don't use Lucas:
WOW! that is baaad news right there.
Old Apr 12, 2005 | 08:44 AM
Default Re: Tranny Fluid Mixture for this summer. Check out my mixture!!! (jweller)
ok, i read that site. Wow, that is crazy. I would like a test done on like Mobil 1 oil. just to see what happens to oil that i use all the time.
Old Apr 12, 2005 | 09:04 AM
mmuller's Avatar
Mad Scientist
GM synchromesh beats all, no debating about that
Old Apr 12, 2005 | 09:21 AM
Honda Hick's Avatar
Default Re: Tranny Fluid Mixture for this summer. Check out my mixture!!! (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">GM synchromesh beats all, no debating about that</TD></TR></TABLE>
Oh yea, it is definately good stuff, but a little extreme if you don't have any worn synchros or bearing noise. That craps expensive too!
Old Apr 12, 2005 | 03:07 PM
95lstegman's Avatar
Honda Genuine MTF all the time. that's what i use to lube up trannies when i put 'em together; that's what i run in 'em day in, day out.
boosted91crx
18
Feb 6, 2009 06:46 AM
Mario.
Mar 24, 2004 10:06 AM
daklown
11
Oct 15, 2003 11:09 AM
EK45VTi
30
Jun 5, 2003 05:49 PM
egNYC
19
Nov 19, 2002 02:24 PM
