changin the key switch in a first gen rex
ok i give up i cant find the keys to my project car how can i change the ingnition key switch and door locks in teh honda ive done it to cheviys and fords but dont know how to on a honda any one thanx
Pull the steering column covers(top and bottom). The ignition lock is held by two round bolts and nuts. You can either take a Dremel tool with a cutting disc and cut a slot on the tops of the round bolts so you can remove them with a screwdriver, or you can take an old screwdriver and hammer tap the edges of the round bolts counterclockwise to remove them.
The easiest solution is to find your key code. If you remove the lock on the lid of your rear storage compartment, it has a key code. Take it to a Honda dealer and they'll cut a new key for you. You can also get the key code from the hatch lock. The ignition lock cylinder has the key code as well. It is the last four numbers!!
Hope that helps!!
Hope that helps!!
fubuallstar
Mar 6, 2008 01:53 PM
SpoolinEK9
Dec 6, 2005 03:32 PM
