d16a6
Old Apr 11, 2005 | 07:12 PM
Hatch1990SI's Avatar
Default d16a6
What would be the best tranny to fit on a d16a6 i have the 90 si
Old Apr 11, 2005 | 07:30 PM
dr_latino999's Avatar
Default Re: d16a6 (Hatch1990SI)
Your transmission unless you build a hybrid transmission utilizing SI/ZC parts.
Old Apr 11, 2005 | 07:32 PM
kulangot's Avatar
Default Re: d16a6 (dr_latino999)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 &raquo;</TD></TR><TR><TD CLASS="quote">Your transmission unless you build a hybrid transmission utilizing SI/ZC parts.</TD></TR></TABLE>
Old Apr 11, 2005 | 07:33 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: d16a6 (sirq2u)
heck i rather the stocker for that lil more free way rpms but thats my $.02
Old Apr 11, 2005 | 07:41 PM
EP3_05's Avatar
Old Apr 11, 2005 | 07:48 PM
UltimX's Avatar
Default Re: d16a6 (91civic)
ex tranny is good too...
Old Apr 11, 2005 | 07:50 PM
Default Re: d16a6 (UltimX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltimX &raquo;</TD></TR><TR><TD CLASS="quote">ex tranny is good too...</TD></TR></TABLE> Same thing.
Old Apr 12, 2005 | 12:41 PM
UltimX's Avatar
I knew someone was going to say that. I'm talking about the next gen ex tranny... s20 i think it is.
Old Apr 12, 2005 | 12:42 PM
EP3_05's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltimX &raquo;</TD></TR><TR><TD CLASS="quote">I knew someone was going to say that. I'm talking about the next gen ex tranny... s20 i think it is.</TD></TR></TABLE>
If it is hydraulic it is not going to bolt in without a custom mount and clutch actuation system.
Old Apr 12, 2005 | 12:44 PM
fireant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hatch1990SI &raquo;</TD></TR><TR><TD CLASS="quote">What would be the best tranny to fit on a d16a6 i have the 90 si</TD></TR></TABLE>
the 90 si transmission is already awesome.
Old Apr 12, 2005 | 12:53 PM
UltimX's Avatar
yes, i understand that but it bolts up... thats the question.
Old Apr 12, 2005 | 04:26 PM
It will bolt to the motor, but you are gaining NOTHING!
Old Apr 12, 2005 | 04:43 PM
UltimX's Avatar
Your gaining more than just nothing. Your gaining the exact same thing as apposed to swaping in a hf tranny or something else. Its probably the next best thing if not better.
Old Apr 12, 2005 | 05:10 PM
Let me get this straight, by swapping in the S20 transmission you will gain <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltimX &raquo;</TD></TR><TR><TD CLASS="quote">the exact same thing </TD></TR></TABLE> Now explain to me how it is the same if it requires you to develop a front engine mount, custom fabricate a new side mount, and a new clutch activation mechanism?
Old Apr 12, 2005 | 10:32 PM
UltimX's Avatar
Do you know why i even suggested this?
You don't need to develop a front engine mount and custom side mount. lol... your pathetic.....
Spend some time on learning why i suggested this.
Also, He never said he wanted to keep the cable, he also didn't say he hydro either... So shut up.
"What would be the best tranny to fit on a d16a6"
Its people like you who give HT a bad name. to you
Old Apr 13, 2005 | 05:32 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltimX &raquo;</TD></TR><TR><TD CLASS="quote">Do you know why i even suggested this?
Its people like you who give HT a bad name. to you</TD></TR></TABLE>
So you see: A newer transmission that will go right in.
I see: A newer transmission that won't go right in to the chassis that has weak shift forks.
When weighing in the pros/cons of what is the best you have to look at the cost/final product ratio. If you take a SI L3 Cable transmission (approximately $90~ local) you bolt it onto the motor, put eveything back together, and you are done. Final cost, $90 + MTF + 2-3 hours of your time. Take the S20 you have $160, bolt it on to the motor, and then you have your fabrication work. But where is the real world gain? This still has not been brought forth. The only S20 that I would even dream about going through all this trouble for would be the one that came attached to the OBD-1 ZC which had a 4.4FD and had an optional LSD.
Old Apr 13, 2005 | 05:36 AM
WhatThaFrig's Avatar
When weighing in the pros/cons of what is the best you have to look at the cost/final product ratio. If you take a SI L3 Cable transmission (approximately $90~ local) you bolt it onto the motor, put eveything back together, and you are done. Final cost, $90 + MTF + 2-3 hours of your time. Take the S20 you have $160, bolt it on to the motor, and then you have your fabrication work. But where is the real world gain? This still has not been brought forth. The only S20 that I would even dream about going through all this trouble for would be the one that came attached to the OBD-1 ZC which had a 4.4FD and had an optional LSD.</TD></TR></TABLE>
Yeah what he said!
Old Apr 13, 2005 | 05:52 AM
EP3_05's Avatar
I was unaware that this was even possible. Please post some more info because I am interested.
Old Apr 13, 2005 | 07:24 AM
HumanResource's Avatar
Best OEM Cable Combination for ACCELERATION:
89-91 JDM INTEGRA SOHC ZC 4.437 FD + 89-91 JDM DOHC ZC 1-4 gears
PLUS OEM LSD
IT would probably take a few years to build it just TO FIND ALL THE PARTS!!!
I'm running the SOHC ZC 4.437 FD open diff
with a short light wheel & tire combo - It's bananas!
YOU could build a quicker box with aftermarket FD's and LSDs but prices go WAY UP
Old Apr 14, 2005 | 07:32 PM
UltimX's Avatar
Well atleast you got the idea of why I suggested this. He never said anything about cost or anything... plain and simple. It was just an alternative to something other people already said, that being the l3 SI transmition. Its also funny you suggesteded that it was the same transmition when I was talking about some other. That being said, I should of said s20 and not ex, but I figured people would be smarter than just saying its the same tranny and be a little more open minded. Not that it ever hurt anyone but most people think inside of the box, so maybe the starter of the post should of specified that what his price range and options where. Also maybe you should of been a little more open minded and thought, "maybe he means some other transmition?" but thats just me. I'm through arguing over the internet. It's pointless. With that being said, if you want to bash me and continue to show everyone else the intelligence you have, go right ahead, I don't care.
Old Apr 14, 2005 | 07:42 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltimX &raquo;</TD></TR><TR><TD CLASS="quote">That being said, I should of said s20 and not ex,</TD></TR></TABLE> Meh, as a devoted sedan man I thought you were referring to the first generation EX since this is the fourth generation forum. But what the hell, no hard feelings. Have a
zc-hatch
Jan 17, 2007 04:36 AM
baboracus
12
Sep 20, 2006 12:24 PM
h22_crx
Jan 9, 2006 08:26 AM
kevo2k6
Jan 14, 2005 09:23 PM
crxzcracer
31
Jul 8, 2004 04:45 PM
