Problems HELP!
Old Apr 11, 2005 | 05:18 PM
StreetEG's Avatar
Default Problems HELP!
B16a in a 92 cx hatch
intake
Worldsport exhaust
93 octane
shittball mugen program chipped ecu
Today i changed to plugs trying to fix a sputtering problem, and there was some oil in the chambers ... is that uncommon?
changed the plugs and the fuel filter
wires and dizzy, cap, rotor were all changed when i did my swap 3 months ago.
I ahve a 1 wire o2 sensor, but the car just recently started sputtering, so i doubt that has something to do with it, but i will be changing that out soon.
PLEEEEEEEEASE HELP ME im going nuts trying to figure this out
Eric
Runs and idles fine, no drastic drop in power just horribleness when it comes to sputtering
Modified by StreetEG at 6:50 PM 4/11/2005
Old Apr 11, 2005 | 05:26 PM
dgrave's Avatar
Default Re: Problems HELP! (StreetEG)
yea not good... check all seals...oil in the spark plug chambers?? something could be cracked.. but doubt it... check all the seals...i dunno if it could be headgasket... nah....but worth a check...usally car sputters if map sensor is bad...
Old Apr 11, 2005 | 05:30 PM
hondapwr's Avatar
Oil sitting on top of the plug where the wire connects is normal if you have a leaky valve cover gasket. There are 4 round seals that are used around the plugs.
Old Apr 11, 2005 | 05:38 PM
StreetEG's Avatar
Default Re: Problems HELP! (hondapwr)
My valve cover has been off a few times, once for a new cam seal 2 weeks ago, and like one other random time... hopefully thats the case... Im hearing it could be the rings?
sputtering happens both pre vtec and during
Old Apr 11, 2005 | 05:52 PM
LShatchie's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetEG &raquo;</TD></TR><TR><TD CLASS="quote">Im hearing it could be the rings?</TD></TR></TABLE>
The piston rings? Does ur car smoke?
Old Apr 11, 2005 | 06:01 PM
StreetEG's Avatar
Default Re: Problems HELP! (LShatchie)
I dont think so, i mean it shoots black smoke when i floor it as per my dad...but i think its cause im running rich because of the mugen and i have a test pipe
Old Apr 11, 2005 | 07:23 PM
StreetEG's Avatar
up...helppppp its so annoying im losing power this is so annoying
Old Apr 12, 2005 | 12:41 PM
StreetEG's Avatar
ttt whats wrong with my car!
Old Apr 12, 2005 | 08:20 PM
dgrave's Avatar
wat did you do so far?? compression test your cylinders...black smoke usally means u have an leak or just buring really rich...and wat exactly is on your car? is your timing retarded?? do you see any leaks? check all the gaskets...exhaust manifold gasket (not that is the problem) check headgasket...if your exhaust is to big you will lose back pressure but it wouldn't cause your car to sputter....what kind of oil are u using?? did you switch from regular oil to synthetic?? if you did... do an engine flush and use regular 5w-30....switchin to synthetc (on an older engine) will clean old oil deposits and dirt would could actually be a bad thing...the oil deposits and dirt become protection.... and f the mugen ecu it could b throwing your timing off... c if a stock ecu will fix ur prob....depending on ur intake man (just to see wat happens) i... and again check your sensors (map sensor would cause sputtering and stallage)... r u gettin an obd code?
hmtcrxsir
Mar 2, 2011 10:43 AM
not-a-stang
Apr 8, 2008 08:45 AM
frog169
Apr 2, 2007 12:12 AM
ZWK
Mar 27, 2007 05:50 AM
Junkyard2000
Jan 10, 2006 07:47 PM
