code 16 help!
Old Apr 11, 2005 | 05:16 PM
adeline's Avatar
Default code 16 help!
My car has a cel light and a code 16. I changed the fuel injectors and my car would still sputter and almost die when you give it gas. I have two sets of injector hf and si and they both do the same thing. When I take the fuel rail off it spills fuel ever were.
Old Apr 11, 2005 | 05:34 PM
mr. carpenter's Avatar
Default Re: code 16 help! (adeline)
code 16 is a faulty ecu. the car shouldn't run. what you're describing sounds like the ignitor on the dist. going out.
Old Apr 11, 2005 | 05:41 PM
adeline's Avatar
Default Re: code 16 help! (mr. carpenter)
I have a new dizzy. code 16 is fuel injector, main relay, resistor box.
Old Apr 11, 2005 | 05:44 PM
i'm sorry i was reading the85 through 87 code list. you are correct. what injectors did you put in?
Old Apr 11, 2005 | 05:48 PM
i'm horrible today. are you smelling fuel when the car is running?
Old Apr 11, 2005 | 05:49 PM
adeline's Avatar
I was running my si and then I tried my hf and had the same results, but I still have the cel from the time I try and start the car.
Old Apr 11, 2005 | 05:55 PM
is the dist. brand new or remanned? not likely but i have taken one back before. i'd run some fuel cleaner through it first. i use chemtool b12. have you replaced the fuel filter?
Old Apr 11, 2005 | 06:02 PM
adeline's Avatar
yes. brand new not remaned
Old Apr 11, 2005 | 07:03 PM
cbrodac0424's Avatar
i had the same problem with my car and it used to dual point and someone before me converted it to multipoint and the wire coming from the resistor box that was connected to the main relay was clipped in there and shorted out so i would start with the wiring of the resistor box and move on from there good luck to you pm me if you have any questions.
Old Apr 11, 2005 | 07:13 PM
adeline's Avatar
Default Re: code 16 help! (cbrodac0424)
thanks will do.
93LsVx
Aug 28, 2010 09:20 AM
hatch_kidb18b1
Jul 30, 2009 03:17 PM
TheCheeseWedge
Jun 3, 2007 10:48 PM
teg969
Mar 21, 2005 10:57 AM
