I need help......ASAP....
Old Apr 11, 2005 | 04:44 PM
730_Si's Avatar
Default I need help......ASAP....
hey guys i have a quick question for anyone that knows how i can fix this problem. today i was installing my new power carbon fibre mirrors on my 93 civic si hatch. i started with the driver side mirror. got it mounted and wires pluged in. i turned the key to accessories and the power adjustment worked but whenever i pushed the up or down adjustment the mirror would do the opposite (left and right was ok). i turned the key to the off position and switched the wires....but the same thing happened. anyways now none of the power mirror adjusment works at all....not even on the stock mirrors. also the blower for the heat/ac does not work either. does anyone kno off hand wat i messed up and how i can fix this?
Thanx in advance.
Jim
Old Apr 11, 2005 | 04:48 PM
LShatchie's Avatar
Default Re: I need help......ASAP.... (730_Si)
Sound like maybe you blew a fuse, try checking ur fuses.
Old Apr 11, 2005 | 05:15 PM
730_Si's Avatar
Default Re: I need help......ASAP.... (LShatchie)
I have already checked all the fuses, could it be anything else??
Old Apr 11, 2005 | 05:19 PM
coupe_hybrid's Avatar
If it's not the fuse then Take the blower Off and test it with a battery to see if it works. It's under the dashboard on the passenger side.
Old Apr 11, 2005 | 07:36 PM
730_Si's Avatar
Default Re: (coupe_hybrid)
its not the blower. everything was working fine before i went to install my new mirrors. the mirror adjustment button doesnt work....and neither does the blower as a result of my mistake while tryin to install the new mirrors. anyone else have any ideas about what i screwed up here?
thanx guys
Old Apr 12, 2005 | 07:30 AM
730_Si's Avatar
Default Re: (730_Si)
anyone??
Old Apr 12, 2005 | 08:42 AM
Contraband's Avatar
id say check the fuses, dont juss eyeball them. you might miss something, take them all out and check them.
Old Apr 12, 2005 | 09:12 AM
730_Si's Avatar
Default Re: (LS95eg)
i used a voltage tester and tested both sides of each fuse. they are all good. it has to be something else. a relay mayb? i dunno im stumped and really want to get this problem solved so i can use my mirrors and put my car back together.
Thanx for all the input so far guys.
Old Apr 12, 2005 | 08:17 PM
730_Si's Avatar
anyone else have any input?
Old Apr 14, 2005 | 01:11 PM
730_Si's Avatar
someone has to know how a can fix this problem. please help.
datssoled
Jul 30, 2009 09:54 AM
djsire
Aug 30, 2007 10:15 AM
