Squeal from the TB/intake mani?
Old Apr 11, 2005 | 03:50 PM
Luka's Avatar
Default Squeal from the TB/intake mani?
Hey i drive a 91 si with a 92 zc swaped in, a few months ago i started hearing squealing i thought it was my air box. it was tottaly throttle resposive(the squeal).
i didnt have the time to really look into it but i just checked and its coming from the TB/IM. Ive been told the idle adjustment screw might be in to tight, but i havent messed with it since i swaped the motor 8 months ago.
any info would be greatly appreciated.
Lucas
Old Apr 11, 2005 | 04:01 PM
mrquimbie's Avatar
Default Re: Squeal from the TB/intake mani? (Luka)
I had this same noise after my mpfi swap. As far as I have read on H-T it is coming from the idle screw. You can lessen the noise by unscrewing the screw but this of course will raise your idle. I was thinking about taking off the TB and changing the hole that lets in air behing the idle adjust screw but I haven't gotten around to it yet.
Old Apr 11, 2005 | 05:28 PM
D-Atk's Avatar
I have that problem as we speak, it's my intake manifold gasket try while the car is running spray some brake parts cleaner at the inatke manifold gasket and it should stop. This noise will only go away for a day or two.
Old Apr 12, 2005 | 05:36 AM
Luka's Avatar
not much then ehh?
dubstackz
Apr 10, 2017 11:43 AM
_MMR_
Feb 10, 2014 05:57 PM
redline303
43
Nov 18, 2010 02:40 PM
Baron55
May 14, 2007 04:32 PM
IC x Prince
Feb 5, 2003 09:43 AM
