Normal Idle
Old Apr 11, 2005 | 03:37 PM
2 Loe 4 Fat Hoes's Avatar
Default Normal Idle
What's up my Honda freaks well i have a question i want to know what is the normal idle for a 93 honda civic d16z6 im asking this question becouse sometimes my rpm stays in 1000 which i think its normal and out of nowhere it drops to 0 and it doesnt matter if its cold or hot
Old Apr 11, 2005 | 03:39 PM
Oren's Avatar
Default Re: Normal Idle (2 Loe 4 Fat Hoes)
does your CEL come on?
Old Apr 11, 2005 | 04:27 PM
Default Re: Normal Idle (Oren)
Nope well i have a 95 dx and i just had put on a d16z6 on it and one of the injecter were broken and gas was leaking so my rpm was at 0 and when i replaced it the car seemed normal it was staying at the normal rpm and now it started dropping again and i cant find the problem
Old Apr 11, 2005 | 07:32 PM
So does anybody know what s wrong???
Old Apr 11, 2005 | 08:57 PM
*Bump*
Old Apr 11, 2005 | 09:59 PM
Evo-man@20psi's Avatar
Try to adjust idle or it could be you IAC valve
Old Apr 11, 2005 | 10:01 PM
Try to adjust your idle or check IAC valve
Old Apr 12, 2005 | 06:48 AM
mountaindewguy's Avatar
Default Re: Normal Idle (Blue00vtecsi)
check the IACV, but its probably not the problem. check your cap and rotor, plug wires, and plugs.
it could also be a fuel delivery problem (filter/pump)
freakasis
Mar 24, 2009 02:58 PM
kevoweb
10
Apr 3, 2007 02:13 PM
Ronaldo9
Oct 15, 2006 08:23 PM
Firefoxracer
Jun 16, 2005 08:04 AM
stump7117
Mar 27, 2005 09:06 PM
