dyno results from saturday?. ?help
Old Jan 29, 2002 | 09:28 AM
PM-Performance's Avatar
Default dyno results from saturday?. ?help
i checked my old ones and all motor with out the header, no timimg advance and power steering was on and put down 168.?
with the timing advanced and no power steering , and header. best run was 170.2 with a little more fuel .
it was a hell of alot of fuel though. . . . . .do you think that vafc will help me that much ?
the up side is that the tourque went up / / / / /
on the 85 shot i put down 181 ft lbs
on the 60 shot 181 ft lbs. . . so thats a plus at least. ??what do i do ?
Old Jan 29, 2002 | 09:31 AM
JoshRambo's Avatar
Default Re: dyno results from saturday?. ?help (itr206)
even though my numbersturned out kinda weak for my mods i gained like 4 HP and 2lbs of torque after getting it tuned in a little.
Old Jan 29, 2002 | 11:00 AM
Default Re: dyno results from saturday?. ?help (Gravity)
thanks man . . . . anyone else have any ideas?
Old Jan 29, 2002 | 11:06 AM
Big Phat R's Avatar
What's the question?
p.s. your sig IS WAY TOO BIG
Old Jan 29, 2002 | 11:09 AM
Default Re: dyno results from saturday?. ?help (Big Phat R)
why didnt i gain any hp from jdm 4-1 and no power steering and timing advance. . . . .?
is it fuell tuning? too much /not enough timing advance.
just go back to stock ?? what
the car is track proven to be worthy, , ,but on the dyno doesnt do what it should be .
Old Jan 29, 2002 | 12:30 PM
Big Phat R's Avatar
Otherwise did you reset the ECU after the mods? Do you have a CEL light?
Did you do the dyno runs with the same rims/tires, tire pressure and ambient temperature conditions? Are both the readings SAE?
I wouldn't advance your timing if you're using NOS either. KABOOM!
[Modified by Big Phat R, 1:32 PM 1/29/2002]
Old Jan 30, 2002 | 05:25 AM
Mista Bone's Avatar
D Tranny Guru
only 181 torque to the wheels with juice?????
Shame a SOHC can do 200 whp with a 75 shot at 3200 rpm
Old Jan 30, 2002 | 05:29 AM
Default Re: dyno results from saturday?. ?help (Mista Bone)
1st off then thats one bad asssss single cam .
anyway the timing was put to stock on the nos run
i talked to the guys from superstreet yesterday and was forwarded to one of jo jo callos's old chief mechanics
anyway . he said to go back to stock with the timing and fuel and just go up in little incraments from there.
im getting the vafc and some cam gears to tune it more. .. he said i should have no prob getting almost 190 hp na
so that s what im shooting for right now.
i pretty much garuntee i have fuel tuning issues.
Old Jan 30, 2002 | 05:32 AM
also im not beliveing that 200 hp on a single cam on 75 shot . . . i have a 60 shot and put down 40hp more to the wheels . . . . your statement seems a little high dont you think, deffinately since to the wheels stock , you were pushing maybe 80hp?
anyway , im not overly conernced because my car is track proven and i already put out 230 hp with the juice only on for about 2 sec already. . . so i can get the power from it.
Old Jan 30, 2002 | 06:11 AM
Mista Bone's Avatar
D Tranny Guru
Well, do the math.
13.55 @ 100 mph into a 7-8 mph headwind in a 2400 lb car with driver on slicks.
Local ITR with 50 shot on 22x8x15's went 12.7 at 106 2 years ago. He traded it in for a S2000.
I know I'm making 140 crank HP before the spray. Add a 75 shot (about 60 hp really) and you get 200 hp.
Old Jan 30, 2002 | 06:18 AM
B18CXr's Avatar
he,he........you said superstreet
Old Jan 30, 2002 | 06:22 AM
what the hell do you have on that thing without the bottle to push 140whp out of that single cam .
Old Jan 30, 2002 | 10:26 PM
Mista Bone's Avatar
D Tranny Guru
Really simple.
AEM intake, Stillen header, Z6 intake manifold, and CRX Si cam installed in the 1/2 tooth retarded posistion, this was the 135 hp 1.5L NON VTEC SOHC motor.
That and about 350+ 1/4 passes to test each mod. When I went to dyno I was in PERFECT tune. Anything I did lost HP.
Can you tune?
Or can you throw parts at a car?
[Modified by Mista Bone, 2:27 AM 1/31/2002]
Old Jan 31, 2002 | 05:14 AM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
you should be putting down more torque that than. I put down 188 ft lb on the 50 shot, 193 ft lb on the 70 shot.
Old Jan 31, 2002 | 05:23 AM
Default Re: dyno results from saturday?. ?help (RealTypeR)
im also runnig dry shot , , so thats killing me there. . but im going wet like yours, i got the stuff on mon .
anyway im getting a vafc tom and getting some cam gears to get this thing tuned right.
i sw jo jo callos old chief tech and he gave some pointers on the fuel and timing. , , so im gonna try again . he said the timing was too much advanced and stuff and to back off it a little and tune the fuel more.
Old Jan 31, 2002 | 05:28 AM
Dropspeed's Avatar
Thats what I think every time I see him post. I wouldn't flant the 92 suzuki Kanatuna either.
Mattj
Old Jan 31, 2002 | 06:28 AM
Default Re: dyno results from saturday?. ?help (Dropspeed)
whoever thinks my post is too big dont f*king read it then .
Old Jan 31, 2002 | 07:29 AM
Dropspeed's Avatar
Its not the post its your signature below that takes up half the page.
1 2 NV
46
May 27, 2007 07:41 AM
Pondus
Aug 9, 2004 04:11 PM
DC2R714
Sep 2, 2002 07:47 PM
REVolution
Jun 24, 2002 04:56 PM
StinkyTofu
Feb 25, 2002 02:04 PM
