URGENT: Soild CEL, No hum from fuel pump, main relay good....i'm stumped
Okay here is the deal, I was driving home the other night on the freeway, just driving at 70ish and all of a sudden my car died. Soild CEL. Turn the key half way on and there is no fuel pump whirrel sound. So I think the pump was jacked. Well, I pulled the pump and replaced it with one that I know is good. Still nothing. Turn the key on and the CEL on the cluster stays on and there is no sound from the fuel pump.
So I change the main relay with one I know is good (pulled from a running car) and still the same thing.
90 CRX si
b18a1
pr4 ecu
When i hook up the fuel pump directly to a battery it will make the whirrel sound so I know it's good.
It is really rather urgent, I'm driving my other car right now and the ****** smokes hard. So I'd like to get this one done.
90 CRX si
b18a1
pr4 ecu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1boostedhybrid »</TD></TR><TR><TD CLASS="quote">Check the fuses under the hood. You might have blown the main relay fuse. HTH
All of the under hood fuses are good.
</TD></TR></TABLE>All of the under hood fuses are good.
did u test the pump usin water to make sure its workin right? hearin the whirring noise doesnt comfirm its working 100% properly
From: I told you to wait in the truck in Texas, United States
Check this fuse:
It is under the dash...
See quote below:
Modified by 88DXCRX at 6:39 PM 4/11/2005
See quote below:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX »</TD></TR><TR><TD CLASS="quote">Check this fuse:
i was gonna post the exact same thing
but i didnt have a pic
i got owned by this fuse once
swapped main relays, swapped conversion harness, swapped ecu's etc..
does anyone even know what that fuse even does ??
</TD></TR></TABLE>i was gonna post the exact same thing
I pushed my car about a mile because of that fuse..
It will blow if the alternator is overcharging for one thing...
Also Fuse #14 powers the following:
Alternator (voltage regulator)
Emission control solenoid valves
PGM-FI main relay
PGM-FI ECU (IG1)
FUEL PUMP
ELD=eletronic load detector
EACV=electronic air control valve
PGM-FI main relay
PGM-FI ECU (IG1)
FUEL PUMP
That fused owned me. I went out and checked it after the under the hood ones.
Now she is having a problem starting. Coil was jacked too =/
My other car is still smokin' hard
thanks though for the help
its a fuse
same **** happened to me.
check all your fuses
if you dont find any bad
then check em again
its a fuse i had the EXACT same symptoms
DOH shoulda read the whole thread first. oh wel ill leave it up for the archives
then check em again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88DXCRX »</TD></TR><TR><TD CLASS="quote">I pushed my car about a mile because of that fuse..
PGM-FI main relay
PGM-FI ECU (IG1)
FUEL PUMP
i have no idea why mine blew
i was idling my car to cool the turbo and all of the sudden she died
i know a few other ppl that have been owned by this bastard as well
PGM-FI main relay
PGM-FI ECU (IG1)
FUEL PUMP
man ef's are havin electrical problems like no other these days, wtf.
I always thought that a solid light meant bad ecu, but find the oem manual and troubleshoot away.
civic08
Mar 14, 2010 09:26 AM
Aphrodavid
Feb 17, 2005 12:05 PM
