Thieves messed up my ignition.
Old Apr 11, 2005 | 12:23 PM
IDGAF2885's Avatar
Default Thieves messed up my ignition. Help.
I go into my car this morning and it was obvious somebody was in there. Put the key in the ignition and it doesnt feel normal when the key goes in and wont turn. Seems like they tried and shoved a screwdriver in there or somethin, dumbasses didnt get anything. But now my ignitions f*cked.
Whats it gonna take to fix it?
Damn thieves, im broke. Thanks for the help.
Old Apr 11, 2005 | 12:26 PM
EP3_05's Avatar
Default Re: Thieves messed up my ignition. Help. (IDGAF2885)
It is going to take a new steering lock assembly.
#2 in this picture from http://www.hondaautomotiveparts.com
Old Apr 11, 2005 | 12:29 PM
IDGAF2885's Avatar
Default Re: Thieves messed up my ignition. Help. (91civic)
How much would a new cylinder usually run me?
And how big of a job to fix?
thanks
Old Apr 11, 2005 | 12:30 PM
EP3_05's Avatar
It isn't too big of a job but you will probably need new keys. The part is like 200 bucks or so.
Old Apr 11, 2005 | 12:40 PM
manson's Avatar
its a pain in the *** of a job.
the ignition is held in with bolts that you cannot remove. You can get them off, but you gotta get creative.
you'll need a screw drive LONG and a hammer. some people use a cutting wheel and notch the bolt... i pound them loose hitting it at an angle until the screwdriver makes a notch and then hit them loose.
you'll see exactly what im talking about once you get the plastics off.
Old Apr 11, 2005 | 12:44 PM
EP3_05's Avatar
Default Re: Thieves messed up my ignition. Help. (manson)
When I replaced mine I just cut slots in the bolts with a cutting wheel and it was relatively easy to remove. However, I agree that working on the dash or underneath it is a royal pita.
Old Apr 11, 2005 | 01:30 PM
IDGAF2885's Avatar
Thanks for the help, so other than those bolts, luckily i have a cutting wheel, is the job hard after that or pretty straight forward?
....like pretty much get it apart and back together with the new piece?
Old Apr 11, 2005 | 01:32 PM
SoCal EJ1's Avatar
I had to get mine replaced about a week and a half ago... set me back about $450 including labor. Thieves.
Old Apr 12, 2005 | 06:02 AM
manson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IDGAF2885 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the help, so other than those bolts, luckily i have a cutting wheel, is the job hard after that or pretty straight forward?
....like pretty much get it apart and back together with the new piece?</TD></TR></TABLE>
yeah its straight forward. take off the old put on the new....
you'll need to replace the ignition bolts that you notched with either a differnet set of regular nuts and bolts or try reusing the old ones.... i opted to just change it out for regular nuts/bolts which may not be the bes tthing to do because it makes it easier fo theives to remove the ignition, but thats all i had.
Old Apr 12, 2005 | 06:17 AM
DJ_SaNdOz's Avatar
The new key lock is like $400ish from Honda. I bought one from a JY for $45 including 1 key. I have 2 keys for my car now, but saving $350ish is worth it IMO.
Old Apr 12, 2005 | 09:16 AM
IDGAF2885's Avatar
Default Re: Thieves messed up my ignition. Help. (DJ_SaNdOz)
thanks for the replies, guys.
Old Apr 12, 2005 | 10:49 AM
WuShu's Avatar
New User
dremmel with a cut off wheel is your best friend.
Old Apr 21, 2005 | 07:04 PM
ITR#00-1077's Avatar
Does anyone know how to take out the ignition out of the housing... the one on my hatch is broken (the metal housing that holds the ignition) and I need to replace that.. or can it be done???
Old Apr 21, 2005 | 07:18 PM
bagpipe goatee's Avatar
to take the ignition out of the housing, the correct way to do it is to turn the ignition to the first notch and then theres a peg around the rim that will push in, and voila, it pulls right out. however, if you can turn the ignition, you probably don't need a new one. i had to do this once, i drilled the peg out, pulled the ignition out, turned the little notch on the inside to where it would be on the first click , slid the new ignition in
pm me if you need more detailed info.
Petite1234
Oct 28, 2014 04:28 PM
SavMac14
Apr 2, 2013 09:35 AM
VTECdTypS
23
Jan 20, 2005 02:25 PM
