max compression ratio on b16a2 std sleaves?+ other stuff
Old Apr 11, 2005 | 11:59 AM
Aaran's Avatar
Default max compression ratio on b16a2 std sleaves?+ other stuff
hey guys i have a few questions :D
i just recived my b16a2 engine with 52 thou on the clock (to start my build on- i already have a b16a2 in the delsol)
what is the maximum compression ratio i can run on stock 81mm sleeves? and yes i will be boring out an additional 0.5mm and getting new 81.5mm pistons to match (i dont want piston slap smashing my engie to bits a few miles down the road)
any reccomendation for the compression ratio i can run on 98 ron gas? thats the best we have here in the uk - its been suggested i shouldnt go over 11.1(or 11.5.1) compression ratio without a better octane fuel.
leading on from that what cams are going to give me good power at high revs with that compression ratio? (ie: will skunk 3`s? jun 3`s)
for the block i intend on fitting a set of high compression forged pistons and rods and having my crank knife edged and balanced up. any reccomendations on what rod/piston combo work well together to give me the compression ratio i need?
(i dont really want to get the cylinders head skimmed to lower the c/r as i dont want it to affect the cam timing over what the can gears say etc)
any ideas to get me started will be greatly appriciated- im just trying to get an idea of what i can do before i start blowing all my cash on theis engine :D
cheers
aaran
Old Apr 11, 2005 | 12:16 PM
SkRiBLaH's Avatar
Default Re: max compression ratio on b16a2 std sleaves?+ other stuff (Aaran)
are you able to find a GSR block or LS block? it would be better to start off with a 1.8 block at least.
Old Apr 11, 2005 | 12:26 PM
Aaran's Avatar
i looked into starting with an 1800 cc engine(b18c4) but i got the b16 engine for such a good deal i want to mod that. plus i want to see how far i can take a b16 hp wise without sleeving it to a larger dia .
cheers
Old Apr 11, 2005 | 12:46 PM
HondaIntegraR's Avatar
Default Re: (Aaran)
you can put a larger crank and get modded pistons to create more displacement
Old Apr 11, 2005 | 03:08 PM
Aaran's Avatar
i know. but it alters the rod/stroke ratio.
thanks for the info but i really need to know the awnsers to my original question(s)
i havent ruled anything out atm as all i have is just the b16a2 engine. i might fit a b18 crank and custom pistons but i want to look into every option i have first rarther than just rush in :D
cheers
Old Apr 12, 2005 | 09:31 AM
Aaran's Avatar
so any idea what i should run as a max cimpression ratio then?
Old Apr 13, 2005 | 01:34 PM
SkRiBLaH's Avatar
Default Re: (Aaran)
i would stick it in the mid 11's...
you dont need super high compression in these motors to make power
4genaccordfreak
Apr 30, 2014 06:28 PM
Exeed
Apr 18, 2006 11:04 AM
Soon_2b_evil
Nov 16, 2003 07:41 PM
ITR.00-1282
Mar 30, 2003 09:04 AM
