Newly boosted, throwing codes, help, already searched.
Old Apr 11, 2005 | 11:12 AM
Civicman86's Avatar
Default Newly boosted, throwing codes, help, already searched.
OK so i pulled the codes on the car today. (car is a 98 civic with p28 and uber)
Had three cells, the only one I could not find was code 18.
Anyone have a haynes or something to tell me what this is? Also here are the other ones that threw, any ideas why?
41-O2 sensor heater
Could the be cause since the o2 sensor was moved? Ihad to lenthen the wires on the o2 sensor but sodered them all.
20- ELD, i think that might be because I had ELD checked on uber
Old Apr 11, 2005 | 11:26 AM
Slammd Sol's Avatar
check the code agian. A code 18 dosnt exist?
https://honda-tech.com/zerothread?id=1171263
Old Apr 11, 2005 | 12:01 PM
Civicman86's Avatar
Default Re: (Slammd Sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammd Sol &raquo;</TD></TR><TR><TD CLASS="quote">check the code agian. A code 18 dosnt exist?
https://honda-tech.com/zerothread?id=1171263</TD></TR></TABLE>
I hcecked that too and its like it has every other code but 18...
Anyone have ideas on the other 2 codes?
Old Apr 11, 2005 | 01:18 PM
Civicman86's Avatar
cmon guys...
Old Apr 11, 2005 | 03:24 PM
nfn15037's Avatar
Default Re: (Civicman86)
Disable the ELD and the 02 heater (not sure if Uberdata can do that) or better yet fix the broken 02 heater circuit. Either the wires are wrong or the 02 sensor is bad.
Old Apr 11, 2005 | 11:48 PM
Evo-man@20psi's Avatar
Default Re: Newly boosted, throwing codes, help, already searched. (Civicman86)
I will check for you
Old Apr 12, 2005 | 04:04 PM
Civicman86's Avatar
cmon guys...
Old Apr 12, 2005 | 04:14 PM
wantboost's Avatar
Who is Mr Robot?
go into uber, and disable the eld and o2 heater... put the chip back in and see what other cels pop up (if any)
Old Apr 12, 2005 | 05:54 PM
nfn15037's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicman86 &raquo;</TD></TR><TR><TD CLASS="quote">cmon guys...</TD></TR></TABLE>
Did you even read any of the replies?
Old Apr 12, 2005 | 07:46 PM
Civicman86's Avatar
Default Re: (nfn15037)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfn15037 &raquo;</TD></TR><TR><TD CLASS="quote">Did you even read any of the replies?</TD></TR></TABLE>
sure did, ELD is disabled still throwing the codes. I'm going to check them again tomorrow when its not raining. My volts are going crazy too. From liek 13.1 to 13.9 to 14.2 then back to the 13's. all the lights like dim and get bright and dim and get bright.
Old Apr 12, 2005 | 07:52 PM
wantboost's Avatar
Who is Mr Robot?
disable the o2 heater.
what do you mean by lights getting bright and dim? like the dash lights? if so thats a charging system problem, thats what the cel could be... have your charging system checked
kuks24
11
Jun 24, 2019 04:59 AM
pinoyboiwonder
Feb 5, 2006 05:44 PM
bosco500
Feb 3, 2006 01:22 PM
scarface50370
Dec 14, 2005 01:21 AM
turbotime
Jul 20, 2003 08:11 AM
