ek motor mounts
i tried searching and could not find anything that stated exactly what i need,
heres the deal my friend is doing a b18b swap into his 99 ek hatch, we are trying to find what motor mounts and anything else that we need to complete this the easyiest way, thank you for your help in advance
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by one8toh8 »</TD></TR><TR><TD CLASS="quote">i tried searching and could not find anything that stated exactly what i need,
heres the deal my friend is doing a b18b swap into his 99 ek hatch, we are trying to find what motor mounts and anything else that we need to complete this the easyiest way, thank you for your help in advance</TD></TR></TABLE>
A/C Mount - You can use the stock B18 but if you want A/C you will need the bracket from a 99-00 Si, Delsol VTEC, or CRV.
Front Tranny Mount - Need the one for whatever tranny you're using and you can reuse your stock civic rubber.
Rear Tranny Mount - Need a bracket from a 99-00 Si and you can reuse your stock rubber.
Top Tranny Mount - Reuse all your civic stuff here, bracket and rubber.
Drive Side Top Mount - Need a 99-00 Si Bracket (piece with 2 studs) and you can reuse your stock rubber.
eh...on my EK hatch...98...i just used the d series driver side top..worked fine...but maybe not strong enough...as i've heard these are the ones that break...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16delteg »</TD></TR><TR><TD CLASS="quote">eh...on my EK hatch...98...i just used the d series driver side top..worked fine...but maybe not strong enough...as i've heard these are the ones that break...
You can use the mount, but the bracket with the two studs is different from the D series.
You have a B16 though so that's why you didnt have to change that bracket. On B18's the bracket wont line up with the d series mount, since they both use a totally different mount style.
</TD></TR></TABLE>You can use the mount, but the bracket with the two studs is different from the D series.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVIL Hx Coupe »</TD></TR><TR><TD CLASS="quote">
You have a B16 though so that's why you didnt have to change that bracket. On B18's the bracket wont line up with the d series mount, since they both use a totally different mount style.</TD></TR></TABLE>
So when putting a b16 into a EK, you only need #8 and #2 in this pic http://www.hondaautomotivepart...MOUNT and then just reuse everything from my d-series
silookalike
14
Mar 30, 2008 04:02 PM
civicrtype
Apr 11, 2005 04:06 PM
Capt. Jimbo McSubipants
Mar 23, 2005 03:36 AM
