V TEC ISSUES ..PLEASE HELP!!!!
Old Apr 11, 2005 | 12:18 AM
wolf3007's Avatar
Default V TEC ISSUES ..PLEASE HELP!!!!
Ok guys heres my set up, i have a 94 coupe with a b16 with a greedy 18g turbo setup on it. i have a FMU { vortec} and a VAFC . Also i have the missing link and a set of 310 injecters along wiht a walboro 255 fuel pump. I know the best way to go is hondata but i am not trying to make serious power i am just planiing to chill at 10 lbs. i am planing to go ahead and get it tuend on the dyno but i have issues wiht my V tec. Ever since i had the engine in the V tech has not been working witch is about 2 months now, i fully re-built the engine. I tryed everything i tripple cheked the wiring on my VAFC the only thing i am not sure about it is the orange wire i dont think i need to use that , however even when u set the vafc to ***** which is suppose to be stock setting nuthing happens, i unplugged the sensor and there was No check engine light. I am runnign a P28{ yes i know it needs to be chipped to run great} ne ways i got frustreated and thought mabe i did something wrong in the head , so i i hooked the solonoid up to a switch to check it , warmed up the car took it to 5500 hit the switch and it switched over , so i know it is mechically sound. it has to be a wiring problem. i know the ecu is good cuz i put it in my friends car and it works fine? so i am out of ideas can yall please help? mabe its a setting i am not setting right? and i need the vtec to work to tune it cuz on the throttle point settings the seetings switch form low cam lobe to high? please please help me figre this out!!!
butter99
Jul 17, 2006 01:07 PM
Del_Sol_s
Dec 13, 2005 09:49 PM
bigedx
Apr 6, 2004 06:53 PM
