d16z6 in crx distributor question
ok .... we dropped in a d16z6 in a 89si crx but when we dropped in the d16z6 the distributor from the old single cam (d16a6 i think) didnt fit. so i need to know what distributor to use? will a d16z6 distributor work if we rewire it with the obd0 plugs??? or what distributr do i need?? TIA
z6 dist. won't work unless you convert to obd1. Some people get the a6 dist. to work with only 1 leg. personally, I did it and modified (i.e. made) mounts to hold it on all 3 and I still had leaks. BAD leaks. So, convert to obd1, check your oil all the time and enjoy a dirty engine bay, or you can do like me and swap to a diff. motor
blue_egsi
May 22, 2012 12:50 PM
Kris's turbo
Apr 24, 2012 11:10 AM
