h22a coupe times?
what times should i be hitting w/ a 93 civic ex coupe h22a swap with just: 2 1/2" full catback and a cold air? just curious b/c im going to the track next weekend, and i want to know what to expect.. that way i can see what adjustments i need to make.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch34 »</TD></TR><TR><TD CLASS="quote">my guess is mid low 14's if you can drive other wise it will be higher</TD></TR></TABLE>I'd say that's about right.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EvilSol »</TD></TR><TR><TD CLASS="quote">its hard to say man. i mean its all the driver. but with a H22 slapped in my del sol i got a 12.8 the first run ever.</TD></TR></TABLE>
Damn, Popadakis!
Damn, Popadakis!
it really is the driver, you have a fast *** motor but if you cant drive then its like your driven stock a single. my buddy ran 13.5 with bolt ons in is GSR hatch so you can go fast with less motor but you have to know how to use it. just my.02
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NY93CivicEx »</TD></TR><TR><TD CLASS="quote">what times should i be hitting w/ a 93 civic ex coupe h22a swap with just: 2 1/2" full catback and a cold air? just curious b/c im going to the track next weekend, and i want to know what to expect.. that way i can see what adjustments i need to make.
My guess is about 15 to 16 on your first time at the track if you are lucky and then you will have improvements afterwards. Check out this guys H22A logs to see his improvments over time and the things he did.
http://info.honda-tech.com/ind...e_Log
Some tips, would be to lose weight, take everything out of your car to lighten it. Have good tires, see if you can borrow some slicks. Use only a 1/4 tank of gas(less weight), the higher octane the better. Read about shifting.
Some told me this one. (New spark plugs, so you can check out what happens to your spark plugs after the runs.)
InsertCleverSN
Jul 7, 2003 02:21 PM
