b16 altenator against crx engine bay?
we got the motor in. mounts in, just need axles and finish wiring(obd1).
anyways, looks like the altenator is not going to work...it cant be pushed all the way back like it should...it is hitting the driver's side engine bay wall.
so, at the current setting, the belt of course is too long. did you guys bang out the wall to make it fit? swap is an XSI b16.
hold on, get a smaller diameter alternator belt.. I didn't dent mine.. Same with a dozen other people on these boards.. its easier than trying to bang the thing in with the engine in the car.
Also
if you need help wiring, see rywire.com
Also
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XtraFastCRX »</TD></TR><TR><TD CLASS="quote">you're suppose to dent it in .. </TD></TR></TABLE>
thanks for the response, guys.
but im going to have to go with this one:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NikoZai »</TD></TR><TR><TD CLASS="quote">hold on, get a smaller diameter alternator belt.. I didn't dent mine.. Same with a dozen other people on these boards.. its easier than trying to bang the thing in with the engine in the car.
Also
if you need help wiring, see rywire.com</TD></TR></TABLE>
Also
I just did mine this weekend.. HCP mounts, B16a, 91 SI HB
I had to dent it to even mount up the alternator.
It wasn't too hard. I had to pull the intake manifold and alternator brackets off with the motor in the car. Only took about 10 SOLID whacks with a 10lbs sledge.
So it's not true that you can always compensate by adjusting the belt length. I HAD to dent it (not hard to do though)
I have done 3 b16a swaps. (1 for me and 2 for other people)
The 1st one in my sedan I dented the framerail since i was a newb to engine swaps. For the second two I used smaller alternator belts and they wroked perfectly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civic »</TD></TR><TR><TD CLASS="quote">I have done 3 b16a swaps. (1 for me and 2 for other people)
The 1st one in my sedan I dented the framerail since i was a newb to engine swaps. For the second two I used smaller alternator belts and they wroked perfectly.</TD></TR></TABLE>
What mounts? it may have been that I'm using HCP mounts...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civic »</TD></TR><TR><TD CLASS="quote">Hasport billet.</TD></TR></TABLE>
DING DING DING.. I think HCP move the motor far enough back to make fitment an issue. Again, I tried w/o the dent first.
Actually, you want the engine further back. It leaves enough room for turbos, 4-1 headers, and A/C. Also, it pushes the weight further back not leaving the car nose heavy and has straighter axles.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Keith P »</TD></TR><TR><TD CLASS="quote">I just did mine this weekend.. HCP mounts, B16a, 91 SI HB
So it's not true that you can always compensate by adjusting the belt length. I HAD to dent it (not hard to do though)</TD></TR></TABLE>
i have hcp mounts and i had to do the same thing... i dented it out and apparently i didnt do it enough so i had to but a shorter belt as well and as of now it barely clears.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DavilleKy »</TD></TR><TR><TD CLASS="quote">Will this also work on a civic hatch?</TD></TR></TABLE>
******* same car noob why do you think that they are in the same area ?
man i am getting tired of stupidheads
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFMAN »</TD></TR><TR><TD CLASS="quote">
chill the **** out bro. this is the second thread in a row that i've read where you just come in and post some bashing statement. if you're getting angry at these posts, just slam your ******* head into your monitor. ***.
</TD></TR></TABLE>chill the **** out bro. this is the second thread in a row that i've read where you just come in and post some bashing statement. if you're getting angry at these posts, just slam your ******* head into your monitor. ***.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16a@9krpm »</TD></TR><TR><TD CLASS="quote">Actually, you want the engine further back. It leaves enough room for turbos, 4-1 headers, and A/C. Also, it pushes the weight further back not leaving the car nose heavy and has straighter axles.</TD></TR></TABLE>
It also makes the engine closer to the firewall, which if your ever gonna go with itbs then your gonna have a problem. Guess it all depends on where your going with your engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nihonjin »</TD></TR><TR><TD CLASS="quote">guys, i ended up getting an alt belt for the VTEC del sols, and it was short enough. worked like a charm.</TD></TR></TABLE>
banging the wheel well is better to do IMO you let some aggression out and you get to use [pedro voice] a slehg hammer [/pedro]
JDM201NJ
Feb 22, 2005 05:34 PM
