cdm 7871 install q's
Old Apr 10, 2005 | 06:58 PM
vdub08's Avatar
Default cdm 7871 install q's
this is what i have
how is this supposed to work? and what else do i need? like are there mounting brackets to this thing or something, cuz i got it locally from this pretty good guy and he said he was cleaning out his garage and this is what he had and he sold it to me as is
Old Apr 10, 2005 | 08:14 PM
ap716's Avatar
Default Re: cdm 7871 install q's (tofu9000)
i believe ur missing the wire that connect from the player to a harness.
Old Apr 10, 2005 | 09:58 PM
m R g S r's Avatar
you paint your toe nails, or are they naturally silver?
Either way....jOOs a ***!
Old Apr 10, 2005 | 11:11 PM
vdub08's Avatar
eheh funny, that's my mom
any more help will be appreciated. and i believe that red circled thing is for jumpers to adjust stuff cuz theres a little diagram for it on the unshown side
Old Apr 11, 2005 | 01:20 AM
shyboy817's Avatar
You're missing the cd players harness, also you need to get a aftermarket harness for your stock harness in order for it to work, check local audio stores.
and the red circles are rca outputs, (for subwoofer and 4channel amps)
Old Apr 11, 2005 | 03:24 AM
vdub08's Avatar
that is an after market harness because there used to be a clarion screen in the space before i took it out
and where would it go? because normally wouldnt it go into the back?
and do u kno what kinda mounting brackets i need? and where can i get em?
Old Apr 11, 2005 | 09:07 AM
3RdT's Avatar
Default Re: (tofu9000)
u would need an alpine sleeve, n the alpine wiring for that deck. i think i mite have one. pm me.
Old Apr 11, 2005 | 04:07 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tofu9000 &raquo;</TD></TR><TR><TD CLASS="quote">that is an after market harness because there used to be a clarion screen in the space before i took it out
and do u kno what kinda mounting brackets i need? and where can i get em?</TD></TR></TABLE>Can you show a better pix of the plug in the dash, [3rd pix down] that sure looks like an OEM Honda radio plug, if that is so then you will need an Alpine wire harness,[ powers, ground, ant. and amp trigger leads 4 speaker leads and maybe mute and illumination leads] that plugs into the multipin plug you have the red circle around, you will need to get that from Alpine or a dealer, hint, hit up your local Alpine dealers install bays and see if they have one left over from an insurance claim, you will also need a sleave and trim, same place, and if that is an OEM plug in the dash you will need an adpt. harness, [but you may have that already, on the Clarion harness, check. 94
Old Apr 11, 2005 | 07:42 PM
vdub08's Avatar
Default Re: (fcm)
unless the dude that i had take out the deck jizacked my harness as well, im pretty sure its not the oem. cuz i also tried an oem honda deck from a lude that my friend offered to give me for temp but it didnt fit. but i am also an audio noob so for the sake of not making a fool of myself and for the sake of getting this deck into my car asap
here are the pics. sorry my camera sucks so i had to paris hilton them
and thanks for the help guys i appreciate it
Old Apr 12, 2005 | 06:47 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tofu9000 &raquo;</TD></TR><TR><TD CLASS="quote">unless the dude that i had take out the deck jizacked my harness as well, im pretty sure its not the oem. cuz i also tried an oem honda deck from a lude that my friend offered to give me for temp but it didnt fit. but i am also an audio noob so for the sake of not making a fool of myself and for the sake of getting this deck into my car asap
and thanks for the help guys i appreciate it </TD></TR></TABLE>Yea that looks like a Honda plug, http://www.installdr.com click on quick radio wiring info then Honda / acura, you can remove the two red "T taps" that are on the 12v+ acc.and constant wires behind just the plug, then you can just get the Alpine harness and the Honda adpt. harness, wire then together plug them in and you are good to go. 94
Old Apr 13, 2005 | 08:45 PM
vdub08's Avatar
one last question guys
is this
supposed to go into this
because right now i just have a straight black wire with a white stripe and nothing at the end sticking out of there
Old Apr 14, 2005 | 07:26 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tofu9000 &raquo;</TD></TR><TR><TD CLASS="quote">one last question guys
is this
because right now i just have a straight black wire with a white stripe and nothing at the end sticking out of there</TD></TR></TABLE> What I see, is you have a scratch circuled and the CD changer port circuled, or are you talking about the radio ant., male motorola, [spelling] end in the car, and a female pigtail on the HU? 94
Old Apr 14, 2005 | 09:54 AM
99IntegraGS's Avatar
It looks like you're missing the mounting sleeve, the trim ring, and the wiring harness. The thing circled in this pic...
is the plug where the wiring harness plugs in. This harness has the 12v constant, 12v switchable, the ground wire, the power antenna wire, the remote amp turn-on wire, and the speaker outputs if this deck contains an amp.
Pacific Coast Parts Distributors, Inc.
https://www.pacparts.com/alpine/default.cfm
MODEL NO. CDM7871
CAR AUDIO
RADIO/CD PLAYER
2001
To order please click on desired Part # below.
Description Part #
ANTENNA CABLE 01T15513W29
CARRYING CASE 15D01798K01
CD MECH ASSY, DP23S27C 81D30307Y03
CONNECTOR LOC# CH401 (FACE ASSY) 09T25444Y15
CONNECTOR LOC# CH601 (MAIN UNIT) 01T35001Y02
DETACHABLE FACE ASSY 01V46700Y09
DISC TABLE CLAMPER 43A30262Y01
IC LOC# IC104 (TC74VHCT08AFT) 51T15194Y01
IC LOC# IC201 (NJM2150AM) 51T15468Y01
IC LOC# IC301 (TDA7560) 51T35403Y01
LAMP LOC# PL402, PL403, PL405, PL406 65T35324Y02
LASER PICKUP 81B40519Y01
LCD 65T45175Y01
MOTOR, LOAD 01V21600Y50
MOTOR, NOSE 59T65085W01
MOTOR, SLED 01V28100Y58
MOTOR, SPINDLE 01V21600Y55
NOSE BASE 13C21370Y02
NOSE BASE RING 13D21372Y01
NOSE BOTTOM 13D40822Y01
NOSEPIECE ASSY 13D01791K01
OWNERS MANUAL 68P01434K45
REMOTE CONTROL UNIT RUE-4185-P
SERVICE MANUAL 68E32117S01
SIDE BRACKET, L 07D00749K01
SIDE BRACKET, R 07D00749K02
SLEEVE 15D00529K01 ($7.75)
SWITCH LOC# SW601 40T15494Y02
SWITCH LOC# SW602 40T15494Y01
TRANSISTOR LOC# Q101 (FMC99) 48T73888F12
TRIM PLATE 33C01797K01 ($3.02)
TUNER ASSY, MB4A906F 77C31639Y01
WIRE HARNESS 01T75469W23 ($12.06)
Modified by 99IntegraGS at 2:13 PM 4/14/2005
shortstopNE
Jul 26, 2011 08:44 PM
USDMSiR
Jul 28, 2008 06:12 AM
is3oo
Audio / Security / Video
15
Apr 14, 2004 08:47 AM
maxxdout
Oct 26, 2001 06:01 PM
