correct name for a factory welded in body nut?
Old Apr 10, 2005 | 06:44 PM
Wes V's Avatar
Default correct name for a factory welded in body nut?
It's driving me crazy, but I can't think of the correct or commonly used name for a nut that the factory welds to a body piece. As an example, the nuts that the attachment bolts for the rear trailing arms go into. Or the nuts that the rear hatch struts attach to.
I keep thinking that it's just called a "weld nut".
Wes (old and losing my mind) Vann
Old Apr 10, 2005 | 06:56 PM
Sobe_Death's Avatar
Default Re: correct name for a factory welded in body nut? (Wes V)
nut-sert?
Old Apr 10, 2005 | 07:54 PM
Wes V's Avatar
Default Re: correct name for a factory welded in body nut? (Sobe_Death)
Not to be rude, but NO. (and thanks)
A nut-sert is a crimped on nut. Kind of like a pop-rivet.
Wes
Old Apr 11, 2005 | 04:32 AM
Sobe_Death's Avatar
yeah, thats right. i was having a blind moment of "intelligence" there taking a break from my dynamics class.
Old Apr 11, 2005 | 08:14 AM
turbohappy's Avatar
Captured nut?
Old Apr 11, 2005 | 12:31 PM
Wes V's Avatar
Default Re: correct name for a factory welded in body nut? (turbohappy)
Na, a "captured nut" is when the nut is loose, but within a box that holds it in place. The nut for the rear suspension compensator arm is a captured nut. The nut is loose, but can't rotate.
Wes
Old Apr 11, 2005 | 12:52 PM
Want2race's Avatar
threaded section
Old Apr 11, 2005 | 12:55 PM
L-CON1's Avatar
Default Re: correct name for a factory welded in body nut? (Want2race)
weld nut is correct!
Old Apr 11, 2005 | 01:50 PM
Wes V's Avatar
Default Re: correct name for a factory welded in body nut? (L-CON1)
Louie;
Thanks! Weld-nut was what came to my mind, but it just didn't feel right.
(and by the way, where is your shop?)
Wes
Old Apr 11, 2005 | 05:09 PM
L-CON1's Avatar
placentia, orange county.
Old Apr 11, 2005 | 06:09 PM
Bailhatch's Avatar
OMG you should put your hat on backwards and talk about how you pour your heart and soul into each bike that you dont even build the engines for...
Old Apr 11, 2005 | 09:01 PM
L-CON1's Avatar
Default Re: correct name for a factory welded in body nut? (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">OMG you should put your hat on backwards and talk about how you pour your heart and soul into each bike that you dont even build the engines for...</TD></TR></TABLE>hmmmm, ok...
Modified by L-CON1 at 10:15 PM 4/11/2005
Old Apr 12, 2005 | 07:14 AM
Wes V's Avatar
Wow!
Where did that come from Bailhatch?
Wes
Old Apr 12, 2005 | 07:59 AM
ManBearPig4silly's Avatar
um holy crap..........
Old Apr 12, 2005 | 10:32 AM
L-CON1's Avatar
Default Re: (silly4lude)
wasnt toward anyone, i already talked to him (he was tired)!
Old Apr 12, 2005 | 10:48 AM
ShowtimesDC2's Avatar
Default Re: (L-CON1)
We usually just call it a "bung".
Old Apr 12, 2005 | 01:16 PM
Wes V's Avatar
Default Re: (ShowtimesDC2)
Interesting!!
I couldn't argue with the term "bung" at all. I do wonder what your history is that you would use that term? Normally I'd think of a bung as a welded (or brazed) fitting for fluid lines.
Old Apr 12, 2005 | 01:19 PM
xci_ed6's Avatar
for the effort, but rather out of place for an obscure orange county choppers reference.
Old Apr 12, 2005 | 01:25 PM
Default Re: correct name for a factory welded in body nut? (krustindumm)
Wes V, I agree. My "history" as you asked for is, I started out in a Hydraulic/Pneudraulic facility(which is where I learned the "bung" term) and am now currently a Heavy Mobile Equipment Mechanic with a focus on sheet metal repair and related fab work.
k3ntegra
Suspension & Brakes
May 30, 2022 09:54 AM
gutted-dx
14
Nov 6, 2013 10:21 AM
vinuneuro
Suspension & Brakes
Mar 4, 2007 12:02 PM
B18EG6
Suspension & Brakes
Aug 25, 2006 09:09 AM
Vinceg99
Apr 17, 2004 06:47 AM
