keyless entry remote won't work if car interior is hot
Old Apr 10, 2005 | 06:22 PM
AlxSiR7's Avatar
Default keyless entry remote won't work if car interior is hot
i have the clifford matrix 3.5 with remote start and the 2 way pager. i've noticed that if my car is out in the sun and the interior heats up too much the reciever inside the car won't read the signal from my pager. it's really weird & i can't figure out why it is doing this.. i have to park in the shade when i can and leave my windows cracked and usually that will do the trick. but if it doesn't i have to use the key and my alarm goes off. anyone ever have this problem or have any ideas how to fix this?? i already moved the reciever from the standard windshield mount to under my sun visor on the headliner..
Old Apr 11, 2005 | 01:15 PM
AlxSiR7's Avatar
Default Re: keyless entry remote won't work if car interior is hot (AlxSiR7)
....anyone???
Old Apr 11, 2005 | 03:19 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlxSiR7 &raquo;</TD></TR><TR><TD CLASS="quote">....anyone???</TD></TR></TABLE> It could be a few things, the ones you can check are the ant. connections, make sure they are pluged in properly, [all the way] the other thing is cold solder joints in the alarm brain or the ant.]
All DEI alarms, [Clifford is one of them] come with a liftime warranty on everything except the remotes, and as your problem seems to be in the parts in the car, [brain and ant.] just take it back to where you got it and have them fix it. 94
Old Apr 11, 2005 | 09:05 PM
AlxSiR7's Avatar
Default Re: keyless entry remote won't work if car interior is hot (fcm)
yeah well.. it was in the car when i bought it but i know some people who might be able to help me out.
Old Apr 18, 2005 | 05:24 PM
vitrox's Avatar
a common problem with all remote starts and security is that in the programming they only program the units to work in a certain temperature. with autostarts in the northwest we have -40F - 90F, or somewhere around there. the lower the temp the unit will work at the more it cuts into the high temprature which is most likely your problem.
Old Apr 18, 2005 | 05:26 PM
gaydm.accord's Avatar
funny mine started doing this recently i would arm my car and come back to it unlocked but the alarm goes off when open.
i could arm and un arm but the doors dont actually lock or unlock.
Old Apr 18, 2005 | 06:31 PM
fcm's Avatar
fcm
Old Fart
Default Re: (vitrox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vitrox &raquo;</TD></TR><TR><TD CLASS="quote">a common problem with all remote starts and security is that in the programming they only program the units to work in a certain temperature. with autostarts in the northwest we have -40F - 90F, or somewhere around there. the lower the temp the unit will work at the more it cuts into the high temprature which is most likely your problem.</TD></TR></TABLE> You can't program the the alarm for temp. you can program the remote start to auto start at a set low temp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gaydm.accord &raquo;</TD></TR><TR><TD CLASS="quote">funny mine started doing this recently i would arm my car and come back to it unlocked but the alarm goes off when open.
i could arm and un arm but the doors dont actually lock or unlock.</TD></TR></TABLE> If your alarm is arming and disarming, but the doorlocks don't work the problem is in the doorlocks, if they are OEM doorlocks and they work with the OEM door switchs then there is a problem with the alarm or the hookup from the alarm. 94
Old Apr 18, 2005 | 07:25 PM
AlxSiR7's Avatar
Default Re: (fcm)
hm.. well at least someone has the same problem as me. still cant figure it out.. if i use the key to get in and open up all the windows while the alarm is going off and let the sender cool off then try to disarm it works.
Old Apr 19, 2005 | 08:30 AM
fcm's Avatar
fcm
Old Fart
Default Re: (AlxSiR7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AlxSiR7 &raquo;</TD></TR><TR><TD CLASS="quote">hm.. well at least someone has the same problem as me. still cant figure it out.. if i use the key to get in and open up all the windows while the alarm is going off and let the sender cool off then try to disarm it works. </TD></TR></TABLE>Your problem is probably a cold solder joint someplace in the RF section of the alarm, ant., ant. connection, or in the RF section inside the alarm brain, when things heat up, they expand, that is probably what is happening with your alarm, the circuit board heats up and expands and brakes a connection, and when things cool down again the connection is good again, this is not an uncommon problem with car elec. 93
BTW The only way to fix it, is to find the cold solder joint and resolder it, this can be hard to do, as they, [the solder joints] are very small, if you want to try it you will need a solder pencil, very fine tip, some 60/40 resin core solder and a good magnifing glass, pull the board out of the alarm case, flip the board over to the solder side, and start looking at the connections through the mag. glass,start looging around where the ant. is connected to the board, when you see a cold solder joint you will know it, the other thing you can do is just resolder the connections, you will not need to add very much solder, [if any] just touch the clean tip of the solder pencil to the connection till it melts the solder the pull it away, to keep the tip clean, [very important] just wipe the tip on a wet sponge, adding a little new solder to it every once in a wile, and wiping it off on the sponge, you can get a solderpencil that will work for $10-$20 ar RadioShack, if you don't have one, [just let them know what you want it for]
Old Apr 25, 2005 | 09:45 PM
vitrox's Avatar
Default Re: (fcm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fcm &raquo;</TD></TR><TR><TD CLASS="quote"> You can't program the the alarm for temp. you can program the remote start to auto start at a set low temp.
ahh but you are so so wrong.
what you speak of is a cold start, which is a temp sensor that goes onto the radiator hose and detects when the coolant reaches a certain temperature and then starts the car to warm the motor.
i've installed hundreds of autostarts and have spoken to the engineers that make them many times, and yes they do program temp limits into them.
Old Apr 26, 2005 | 06:36 AM
fcm's Avatar
fcm
Old Fart
i've installed hundreds of autostarts and have spoken to the engineers that make them many times, and yes they do program temp limits into them.</TD></TR></TABLE> And I have been installing remote starts since they came out, all kinds, starting in Winnipeg MB where it can be +35C in the summer and -30C in the winter, I have checked my shop manuals for the 7 remote starts the we do or have carried in our store, [ Coumpustar, Autostart, Polarstart, Bulldog, Astrostart, Commandstart and the DEI remote starts] and not one of them have a upper or lower temp. limit, not even Commandstart, [one of the originals] and what would be the point? 94
myst
Audio / Security / Video
21
Dec 5, 2007 02:40 PM
dukers
25
Aug 4, 2005 09:38 PM
icedaccord19
13
Mar 28, 2004 09:07 PM
black sohc civic
Apr 25, 2003 07:13 AM
