Head unit grounding
I'm going to be installing my new pioneer 6700 and thinking about where I should ground it. How many of you guys with aftermarket decks grounded it through the harness or tapped it somewhere else? If you mounted it through the harness have you run into any problems?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phayzeone »</TD></TR><TR><TD CLASS="quote">I'm going to be installing my new pioneer 6700 and thinking about where I should ground it. How many of you guys with aftermarket decks grounded it through the harness or tapped it somewhere else? If you mounted it through the harness have you run into any problems?</TD></TR></TABLE> Use the harness ground, and when you brace the back of the unit, use a metal strap or bracket so it grounds the chassis of the HU to the chassis of the car.
94
94
adrenaline_nsx
Audio / Security / Video
Feb 5, 2010 01:31 PM
