MPFI swap on an auto
Old Apr 10, 2005 | 05:52 PM
darb2k's Avatar
Default MPFI swap on an auto
can it be done?? if so id probably need all the same parts as if you were doing one to a manual, but just a different ECU?? thanks
Old Apr 10, 2005 | 08:15 PM
dr_latino999's Avatar
Default Re: MPFI swap on an auto (darb2k)
Yes you would need the ECU from an Automatic equipped Civic EX, which should be rather interesting as they were only produced in 90-91.
Old Apr 29, 2005 | 01:14 AM
crex23's Avatar
Default Re: MPFI swap on an auto (dr_latino999)
Bump for some help, as I will probably be doing the mpfi swap in my auto DX soon. I searched for mpfi auto, but didn't get much help. Anyways, I read that all parts need to be from a 90-91 auto Civic EX because of vacuum lines and such that manuals don't have. Is this true? I have a buddy with most of the parts for the swap, but they are from a manual car.
Old Apr 29, 2005 | 01:20 AM
Bad89rex's Avatar
didn't CRX Si's come auto as well. I think as long as it's an Auto. Si, or EX that's the ECU you need.
Old Apr 29, 2005 | 06:52 AM
Default Re: (Bad89rex)
No automatic SI's to my knowledge. You will need to source an ECU from an automatic EX or an automatic 88-89 Integra.
Old Apr 29, 2005 | 07:38 AM
red97tj's Avatar
i've just swap over my 88 lx w/ a dohc zc engine/auto tranny combo.
i bought a auto zc ecu (pm7 ecu w/ numbers starting w/ 641 on second line of serial sticker...if 640 is for 5spd) on ebay. it's running alright but i haven't been able to find info on the wiring for the second lock up solenoid on the auto tranny...so the ecu is throwing a 19 code...uhhhh!!!
let me know if you need more info...
Old Apr 29, 2005 | 07:46 AM
Brownjd's Avatar
Default Re: (red97tj)
i might be wrong, but i thought you can convert an ecu from auto to manual and manual to auto pretty easily
Old Apr 29, 2005 | 07:51 AM
LSVTEC 91 Civic's Avatar
Banned
Auto P28 with a Mini Me
Old Apr 29, 2005 | 08:07 AM
darb2k's Avatar
Default Re: (LSVTEC 91 Civic)
so someone said something about the vaccum lines, is that true??!
Old Apr 29, 2005 | 10:41 AM
crex23's Avatar
Default Re: (darb2k)
This is the post I was reading about:
https://honda-tech.com/zerothread?id=411366
Can anyone else confirm that all parts (manifold, TB, etc) have to be from an auto car?
Old Apr 29, 2005 | 10:54 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: (Brownjd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brownjd &raquo;</TD></TR><TR><TD CLASS="quote">i might be wrong, but i thought you can convert an ecu from auto to manual and manual to auto pretty easily
It's easy on OBD-1 ECU's, but I couldn't get an answer on OBD-0 ECU's. I ended up just buying a manual PM5 for my auto to manual swap for $20 [I'm going auto to manual but staying DPFI].
Old Apr 30, 2005 | 07:31 PM
crex23's Avatar
Default Re: (DaX)
Bump for some help
Old May 1, 2005 | 06:45 PM
crex23's Avatar
Default Re: (crex23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crex23 &raquo;</TD></TR><TR><TD CLASS="quote">This is the post I was reading about:
Can anyone else confirm that all parts (manifold, TB, etc) have to be from an auto car?</TD></TR></TABLE>
Ef4doorwagon
Aug 26, 2015 09:44 AM
qcty_jdmes1
Honda Civic (2001 - 2005)
Oct 15, 2009 02:41 PM
bonies
24
Aug 30, 2009 11:00 PM
Steve90HB
Feb 19, 2004 10:38 AM
Crxer
Feb 10, 2003 04:11 PM
