Can't afford a chop saw ? The solution has arrived
Old Apr 10, 2005 | 03:16 PM
RCautoworks's Avatar
Default Can't afford a chop saw ? The solution has arrived
Jk, wonder how straight it cuts though, only 6 bucks to
CUT-OFF SAW CONVERSION KIT
Save hundreds of dollars on a cut-off saw! Turns your 4'' or 4-1/2'' grinder into a cut-off saw. For grinders with two side handle mounts.
Base dimensions: 9-3/4'' x 9-3/4''
Maximum vise opening: 4-3/8''
ITEM 40613
Or would you like to spend a little more, for 15 dollars you can get this
MINI CUT-OFF SAW
Make perfect cuts in steel, brass, aluminum, and wood in 1/10th the time it takes by hand. So accurate that you may never have to file or sand ends.
Includes one 2'' dia. high speed steel blade
Motor: 110V, .9 amps, 7800 RPM maximum
Cutting capacity: 3/4'' depth
Miter gauge: 0° to 45°
Base: 5-1/2''L x 5''W
Overall dimensions: 9''L x 5-1/2''W x 6-3/4''H
ITEM 42307
Old Apr 10, 2005 | 05:09 PM
Bailhatch's Avatar
Default Re: Can't afford a chop saw ? The solution has arrived (90blackcrx)
3/4" cut depth
Old Apr 10, 2005 | 05:26 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Can't afford a chop saw ? The solution has arrived (Bailhatch)
funny. i always thought the solution to not being able to afford something was work and save money until you could afford to buy it
Old Apr 10, 2005 | 06:50 PM
4cefed's Avatar
Default Re: Can't afford a chop saw ? The solution has arrived (wantboost)
a chop saw is like $100
Old Apr 10, 2005 | 07:12 PM
accord387's Avatar
i got mine off ebay for 35 shipped. (14" cut off saw that is)
Old Apr 10, 2005 | 11:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">funny. i always thought the solution to not being able to afford something was work and save money until you could afford to buy it</TD></TR></TABLE>
The thread was ment to be sarcastic and a joke. Hints the first word I said was just kidding
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord387 &raquo;</TD></TR><TR><TD CLASS="quote">i got mine off ebay for 35 shipped. (14" cut off saw that is)</TD></TR></TABLE>
What name brand ? And how good does it cut ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4cefed &raquo;</TD></TR><TR><TD CLASS="quote">a chop saw is like $100</TD></TR></TABLE>
Show me a decent one for that price, and not the craftsman one either.
Old Apr 11, 2005 | 06:24 AM
DSMu4ia's Avatar
I bought that mini-chop saw thingy thinking it would be good to do -AN hose cutting with.
**** was I wrong.
It can at best cut fingernails and stuff, one weak motherfugger.
Old Apr 11, 2005 | 09:40 AM
wantboost's Avatar
Who is Mr Robot?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote"> The thread was ment to be sarcastic and a joke. Hints the first word I said was just kidding </TD></TR></TABLE>
I know, i was being sarcastic too
Old Apr 11, 2005 | 04:55 PM
Smokinsax's Avatar
The Boot
at least it looks SUPER SAFE!!
Old Apr 11, 2005 | 06:29 PM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">3/4" cut depth </TD></TR></TABLE>
Rotate the piping.
Old Apr 11, 2005 | 07:10 PM
LostCRX's Avatar
Show me a decent one for that price, and not the craftsman one either. </TD></TR></TABLE>
I got mine at HF for $50. The thing went through hell and back. I made 3 ramhorn manifold with it, with collectors and everything. It works flawless.
Old Apr 11, 2005 | 07:37 PM
2point2's Avatar
i hate chop saws.
i was ]this[ close to posting a "I lost my ******' eye" thread because of a chop saw. Can't clamp el's down veyr well at all.
Old Apr 11, 2005 | 10:38 PM
Vanilla Sky's Avatar
those things use a sewing machine motor... so far, that's like the cheapest i've found the motor for my sewing machine, lol
Old Apr 12, 2005 | 08:53 PM
B18EG6's Avatar
Default Re: (Vanilla Sky)
yeh that second one posted... lol, ive used it. Burnt through two belts, that **** is alright i guess. I used the toothed saw, do they make cof off discs instead of the toothed blade?
Arent those blades just as much as the machine itself?
Old Apr 13, 2005 | 07:02 AM
egizzle8
Guest
Posts: n/a
Default Re: (B18EG6)
I've used my HF 50 chopsaw and cut through cast and made a tons load of **** and still on the same 14" disc. I hardly ever use my angle grinder anymore.
Old Apr 13, 2005 | 06:59 PM
LostCRX's Avatar
Default Re: (egizzle8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egizzle8 &raquo;</TD></TR><TR><TD CLASS="quote">I've used my HF 50 chopsaw and cut through cast and made a tons load of **** and still on the same 14" disc. I hardly ever use my angle grinder anymore.</TD></TR></TABLE>
Word! When I brought my metal band saw home, I hastily put away my chop saw. I took it back out after about 10 minutes. It's so handly for a quick chop job.
Old Apr 13, 2005 | 08:24 PM
Infinite Auto's Avatar
Default Re: (LostCRX)
ya i have to say for a chop saw just hit up harbor frieght, 2hp 14" saw for 50 bucks.....ive had mine for a year with no problems.....just dont be a jackass and try and cuz 3inch steel in 30 sec if you know what i mean
Old Apr 13, 2005 | 10:10 PM
ComputerJLT's Avatar
Default Re: Can't afford a chop saw ? The solution has arrived (LostCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LostCRX &raquo;</TD></TR><TR><TD CLASS="quote">
Word! When I brought my metal band saw home, I hastily put away my chop saw. I took it back out after about 10 minutes. It's so handly for a quick chop job.</TD></TR></TABLE>
Another vote for the HF chop saw!
$50 well spent
Old Apr 13, 2005 | 10:26 PM
Default Re: (B18TurboEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18TurboEF &raquo;</TD></TR><TR><TD CLASS="quote">ya i have to say for a chop saw just hit up harbor frieght, 2hp 14" saw for 50 bucks.....ive had mine for a year with no problems.....just dont be a jackass and try and cuz 3inch steel in 30 sec if you know what i mean</TD></TR></TABLE>
How accurate are the cuts ?
Old Apr 14, 2005 | 05:56 PM
Can you link me to it, could not find it. Only 1 for 100 bucks
Old Apr 14, 2005 | 06:00 PM
Default Re: (90blackcrx)
well id say there about as accurate as a disk spinning can be.....not to be a smart ***, but i think it would only walk if you went too fast if you know what i mean
Old Apr 14, 2005 | 06:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18TurboEF &raquo;</TD></TR><TR><TD CLASS="quote">well id say there about as accurate as a disk spinning can be.....not to be a smart ***, but i think it would only walk if you went too fast if you know what i mean</TD></TR></TABLE>
I don't think a lot of people have a problem with the chop saw walking, its the cheap band saw that walks.
https://honda-tech.com/zerothread?id=1213554
Old Apr 14, 2005 | 08:02 PM
LostCRX's Avatar
Can you link me to it, could not find it. Only 1 for 100 bucks</TD></TR></TABLE>
mine was original at $100. I got it on a 50% sale
Old Apr 15, 2005 | 01:51 PM
hybridmoments's Avatar
man. you are going to have to change disks out all the time. just spend some money on a chop saw.
i got some LMC chop saw from LOWES for less then $100.
hondakook
Feb 2, 2009 11:46 PM
Flux
Oct 3, 2004 04:46 AM
pbaboy
Acura TL, RL & ZDX
Feb 7, 2002 02:54 PM
