GM Synchromesh makign trans leak?
Old Apr 10, 2005 | 03:00 PM
CWBETB's Avatar
Default GM Synchromesh makign trans leak?
ever since I put in GM syncromesh in my 90 Civic's trans it seems to drip whenever I take a drive. I thought my oil pan was leaking but today I touched one of the drips with my finger and it didnt feel like my normal castrol I put in the engine, possibley the synchromesh. Is this possible? Could the synchromesh be to thin that for some reason its leaking out on my trans? I used to use 10w 30 for trans fluid. I also jacked my car up and it was wet around the trans/oil pan area
Old Apr 10, 2005 | 03:08 PM
SiR Inspired ED7's Avatar
Default Re: GM Synchromesh makign trans leak? (CWBETB)
Intresting...i never heard anything like this before, you should inspect your motor/Tranny for any leaks...
Old Apr 10, 2005 | 03:42 PM
leaftye's Avatar
Could be the Synchromesh...
Strangely enough the GM Synchromesh is harmful to some of the older trannies that were bolted up to LS1's (Corvette/F-Body). It seems to deteriote the paper linings on the blocker rings. The newer trannies have carbon fiber blocker rings, and don't suffer from this.
Old Apr 10, 2005 | 03:50 PM
Dave421's Avatar
Did you happen to check the drain bolt? Maybe you didn't tighten it enough. Also check your axles to see if it's leaking from the axle seals.
Old Apr 10, 2005 | 05:35 PM
CWBETB's Avatar
Default Re: (Dave421)
No problems at drain bolt/oil filter, I will need to double check the axel though.
I might be trying the Honda MTF to see if I still have a leak.
Old Apr 10, 2005 | 05:48 PM
NikoZai's Avatar
Default Re: (CWBETB)
did you put the bolt back in the top ? LOL
johnzy00
Honda Civic (2006 - 2015)
Jan 9, 2012 06:45 AM
MattNYC
Sep 8, 2010 05:21 AM
EG6_DREAMS
Aug 20, 2007 05:17 PM
Tonyl507
Dec 8, 2006 09:32 AM
92_EGhatch
Dec 25, 2005 12:00 AM
