engine noises, take a listen
Old Apr 10, 2005 | 01:21 PM
munscher's Avatar
Default engine noises, take a listen
NOTE: apologize for quality, only mic i have is on my digicam
Clip 1
Clip 2
The first 5 or 6 seconds of the first .wav file you can hear an odd recurring noise at idle, then I blip the throttle and you can hear a noise up until around 22 or 23 seconds... after that a new noise comes into play as i hold the throttle at just above idle. The second .wav file isn't as helpful but I added it just in case.
The camera was held about 6 inches from the valve cover. I'm hearing some noise out of what i think is the valvetrain, but there's also a significant amount of pinging type noise coming from the distributor.
Its about time to do a tune up and replace distributor cap and rotor, but if the distributor itself is whats causing the noise then i dont wanna waste the money on the cap/rotor. Can anyone make sense of these noises from what little i've given you to work with?
Also, I adjusted my valves several months ago and rechecked them twice before I ever put the valvecover back on, so i feel pretty certain that they were correct even though it was my first time doing so.
EDIT: Decided to take the distr. cap off and take a look...
Looks to me like some contact is being made and the cap/rotor could very well be the source of some noise b/c of it.
Old Apr 10, 2005 | 02:19 PM
mikesterny's Avatar
that distributor looks fine most of the noise you hear iss related to your valvetrain most likely loose valves or worst case you skipped a tooth and valves are hitting could be auto tensioner? if you have one? definitely would check out the belt and timing
Old Apr 10, 2005 | 02:35 PM
97Preludeguy's Avatar
Default Re: (mikesterny)
Sorry I can't help you find your problem ,however, It sounds like my buddy's YZ125 at idle
Old Apr 10, 2005 | 02:55 PM
five-0's Avatar
Default Re: (97Preludeguy)
That sounds like alot more than the dizzy cap mang. Check your base timing.
Old Apr 10, 2005 | 03:25 PM
Greyout's Avatar
Default Re: (five-0)
it sounds like the Valvecover is missing something...
is the PCV secure? the breather? the oil cap? I ran without a PCV (just a hole in the valve cover) and it sounded a lot like that.
If not, it also kinda sounds like a timing belt flopping around. Its hard to tell w/ a digital reproduction of the sound (through my onboard speaker, no less ) but based on what I hear, thats where I would focus my attention.
edit: and that looks like normal wear on a cap & rotor
Old Apr 10, 2005 | 03:36 PM
munscher's Avatar
Default Re: (Greyout)
thanks for all the replies so far fellas...
I checked everything with the valve cover just now to be sure, and everything is in place and secure.
I'm gonna recheck my valves and timing as soon as i get the chance. Unfortunately that will probably be next weekend at the earliest.
Old Apr 10, 2005 | 03:39 PM
95greenlude's Avatar
spun bearing....kindof what mine sounded like
Old Apr 10, 2005 | 05:20 PM
MackDad's Avatar
Default Re: (95greenlude)
I thought it was an Isuzu Diesel at idle there for a minute...
You definately have a problem with your valve train. I would pull the valve cover and check your tolerances again...Make sure you let the engine sit for 24 hours before you do so...
Old Apr 10, 2005 | 05:24 PM
jnet's Avatar
Default Re: (MackDad)
sounds like my lawn mower.
Old Apr 10, 2005 | 05:40 PM
Greyout's Avatar
Default Re: (jnet)
sounds like some wicked cams and an ITB setup
Old Apr 10, 2005 | 07:25 PM
dubzz24's Avatar
That's what my car sounds like when it's low on oil. Hopefully you checked the obvious though
Tasp72
Feb 16, 2016 04:50 PM
erikiksaz1
Jan 8, 2006 06:23 AM
bleedblue94
Jan 7, 2006 10:08 PM
Xlerate9
Feb 27, 2003 08:31 AM
DOHC 95 hatch
Jan 6, 2003 11:33 AM
