JDM H22A / Coil conversion
Hi,
I search and found a few topics, but nothing really explaining everything clearly. I have a spare MSD Blaster 2 coil and I want to use it with my JDM H22A engine. From what I deduced from other posts, I will need :
- USDM cap
- USDM rotor
- Wire to the coil.
I'll also need to redirect the wiring going into the distributor housing for the coil to my new coil.
Is this correct ? Is there any site with a clear explanation on how to do this and the right parts needed ?
- USDM cap
- USDM rotor
- Wire to the coil.
it's really that easy!
you'll see the two wires on the internal coil. Take the coil right out and send those two wires to your MSD coil. +'ive and -'ive should be labled..
2point6
Mar 14, 2017 08:54 AM
2point6
May 25, 2006 05:21 AM
