b18b swap into a hx
hey,
I'm trying to swap a 2000 b18b that from the looks of it have been converted to odbI and my 2000 hx is an odbII. I bought the complete swap minus the ecu, so I'm going to have to purchase an ecu.
Here is my list of what I need besides what came with the swap.
-obdII p75 ecu
-99-00 civic si rear mounts
-delsol ac bracket
-figure out which engine harness to use
From what I've gather through h-t I think those are all I need. If anyone can suggest something that I've missed or need, please do so. thanks
-obdII p75 ecu
-delsol ac bracket
use the engine harness thats in your car. and make sure you get an obd2b ecu not obd2a because the plugs are different. if the motor is obd1 you'll need to find an obd2 dizzy and injectors. or you could swap the obd2 plugs on your harness to obd1 because obd1 and obd2 electronics are the same.
TURBOED-TEG
Sep 17, 2002 05:05 AM
