91 civic dx 4dr. when she accels we hear a high pich noise from speakers :(
k like the topic says. we hear a high pich noise coming from the driver side speakers. its wierd. we swapped subs and now everytime she accelerates the noise gets louder? wth
Before The Noise
Panasonic Deck
Infinity Speakers
2 10" subs and 250watt amp
Noise Starts
Panasonic Deck
Infinity Speakes
2 12" Subs and 250watt amp
is it because the subs? or can i be the radio itself?
i dont really get it and we cant afford another dime to take it to circuit city and get it checked out :-\ damn money hoggers.
anyone get this problem before?
either that or we hooked the subs wrong. i need an answer
Before The Noise
Panasonic Deck
Infinity Speakers
Noise Starts
Panasonic Deck
Infinity Speakes
From: Good luck to this industry, you're gonna need it.
sounds like you might need what's called a ground loop isolator. it will help cut out any noise...
should be a fairly simple fix...
if the GLI doesn't work, consider looking to see if you ran the signal wires anywhere near something that might make noise (fuel pump etc...). it also could be the quality of your cables, they could be knicked somewhere, and if nothing else, get a power wire noise filter...typically for mechanical noise, but if the ground loop isolator doesn't work, that's you next best bet.
good luck
good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by james4o8 »</TD></TR><TR><TD CLASS="quote">k like the topic says. we hear a high pich noise coming from the driver side speakers. its wierd. we swapped subs and now everytime she accelerates the noise gets louder? wth
Before The Noise
Panasonic Deck
Infinity Speakers
Noise Starts
Panasonic Deck
Infinity Speakes
</TD></TR></TABLE>So the only thing you changed, was from 10" to 12" subs, You didn't replace the HU or amp or change the wiring in any way? You also say the "alt. whine" is only from one speaker?
94
Before The Noise
Panasonic Deck
Infinity Speakers
Noise Starts
Panasonic Deck
Infinity Speakes
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by james4o8 »</TD></TR><TR><TD CLASS="quote">went from bazooka sub package to mtx sub package.
was fine before we switched subs. but wonder why its starting to make noise....
only makes noise when my gf accelerates.</TD></TR></TABLE> Did you change the amp?
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by james4o8 »</TD></TR><TR><TD CLASS="quote">yea i think the amp of bazooka are 250 watt same as mtx ones</TD></TR></TABLE>Ok you changed the amp, and you say the "whine" is only coming from one speaker, [drivers side] and you haven't changed the HU or any of the wiring for the amp, [you used the same power, ground, trigger and RCAs for the MTX as you were using on the Bazooka amp/sub package?]
94
94
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by james4o8 »</TD></TR><TR><TD CLASS="quote">yea its all the same. dont know about the wiring :-\ if i take a picture of the wires could you tell where they go?</TD></TR></TABLE> Yes, also try this, unplug the RCAs at the amp, and disconnect the power, [remove the fuse on the power wire at the batt.] then check and see if the "whine" is still there, and also check and see if the noies is only on one side.
94
94
jjenkins
Audio / Security / Video
Dec 1, 2011 05:35 PM
