Fuel problem
Old Apr 10, 2005 | 04:15 AM
barfetta's Avatar
Default Fuel problem
have a 89 Accord LXI ,3 door coupe , fuel injected. After car is warmed up,3-5 min ,shut it off it will not start and you can smell gas ,if I pinch off the fuel line it will start. If I pull off a connector to an injector , you can hear it trying to fire on that cylinder.
I have replaced the fuel regulator , and all of the components in the box on fire wall.
Fuel filter , and checked pressure and staying at 39psi.
It seems to flooding its self out .
I haven't found a mechanic that can lead me to try anything else .
Modified by barfetta at 5:33 AM 4/10/2005
Old Apr 10, 2005 | 04:32 AM
deserthonda's Avatar
mmm do you mean 88 lxi????you might try unplugging the tw sensor and see how it starts for you ,i am guessing that might be your problem
Old Apr 10, 2005 | 04:34 AM
barfetta's Avatar
Default Re: (deserthonda)
Sorry about year, finger error it is an 89 , and yes did that to know avail
Old Apr 11, 2005 | 06:53 AM
try removing the hose from the charcoal canister that goes into manifold,,also pull out oil dipstick and see if you got gas in crankcase if so drain and put new oil
sgull
Jan 25, 2013 12:43 PM
JDMhondalude22
Oct 26, 2006 02:19 PM
krarthur
Jan 19, 2004 12:40 PM
PUSHER
Jul 3, 2003 10:08 PM
