this is how VTEC works
Old Jan 28, 2002 | 09:00 PM
Bbasso's Avatar
Default this is how VTEC works
I found this while surfing, for those who think they know everything about VTEC you might just want to take a peek!!!
ck this out!!!!
and then the animation...
http://www.hondabf225.com/advvteani.htm
[Modified by Bbasso, 1:01 AM 1/29/2002]
Old Jan 28, 2002 | 09:04 PM
B2FiNiTY's Avatar
Default Re: this is how VTEC works (Bbasso)
I dig the animation.
Dodger2940's Avatar
thanks for posting this info
Old Jan 28, 2002 | 09:05 PM
Mike M's Avatar
Founding Member
Default Re: this is how VTEC works (B2FiNiTY)
Old Jan 28, 2002 | 09:21 PM
Tomakit's Avatar
Default Re: this is how VTEC works (TypeRmsm)
Good Find!
Tom
Old Jan 28, 2002 | 09:22 PM
Bbasso's Avatar
Mike thanks for getting the animation on here...
Old Jan 28, 2002 | 09:58 PM
2005 TSX's Avatar
Default This is how VTEC works
I want one...
...marine outboard power with the new BF225 V6. Inside, it features exclusives like our 24-valve VTEC System for a superior blend of power, torque and fuel economy.
I wonder if that would fit in my GS-R.
People would ask, what do you have under your hood, a four banger?!?!
Nah, I have a:
BF225
3471 cc 212.ci
225 hp @ 5500 rpm
V6
and of course an AEM CAI!!!
[Modified by 2001 Integra GSR, 11:01 PM 1/28/2002]
Old Jan 28, 2002 | 10:26 PM
EG8R's Avatar
Default Re: This is how VTEC works (2001 Integra GSR)
Heh. I knew that
Old Jan 28, 2002 | 10:36 PM
Crazy DA's Avatar
New User
Default Re: This is how VTEC works (mr. skelly)
can the synchronizing piston be activated manually (ie. no oil pressure) to do a clay test on a motor?
the c-speed website says you can but I was told by a local machine shop that it could not be done and to do a clay test without the vtec piston activated. comments??
Old Jan 28, 2002 | 11:51 PM
blackANESE's Avatar
Default Re: This is how VTEC works (Crazy DA)
VTEC for boats............nice
By Land or by Sea you can have VTEC!
Old Jan 29, 2002 | 04:03 AM
SpecR_EK's Avatar
New User
Default Re: This is how VTEC works (captainJDM)
Cool animation
Btw, How does the new iVTEC work? Just curious here...
[Modified by SpecR_EK, 5:03 AM 1/29/2002]
Old Jan 29, 2002 | 04:04 AM
Tbone's Avatar
Yes it can be done via the way c-speed say's you can. But only one of the valves will drop with the vtec cam per chamber. There is also a method useing compressed air to lock all the rockers. It would be pointless to clay the motor without the vtec active, don't ever let that machine shop touch you motor.
Old Jan 29, 2002 | 08:04 AM
AcuraTypeR's Avatar
Sweet
Old Jan 29, 2002 | 08:21 AM
TypeR0149's Avatar
Default Re: this is how VTEC works (AcuraTypeR)
verycool animation mike
Old Jan 29, 2002 | 08:22 AM
TypeR0149's Avatar
Default Re: this is how VTEC works (Vegeta)
The animation is now on my desk top,
any other pics, or animations you can find, would be great
Old Jan 29, 2002 | 09:08 AM
DutchITR1689's Avatar
Default Re: This is how VTEC works (SpecR_EK)
Cool animation
iVTEC is just VTEC + variable timing on intake cam (like VANOS)
more pictures:
copy and paste on a new window
http://www.imagestation.com/picture/...e.gif.orig.gif
http://www.imagestation.com/picture/...d.gif.orig.gif
Old Jan 29, 2002 | 09:11 AM
ThePunk's Avatar
Default Re: This is how VTEC works (EuroITR1689)
That's a sweet animation...
Right-click, save as....
Old Jan 31, 2002 | 03:17 PM
Bbasso's Avatar
"verycool animation mike"
You should be thanking me not Mike even though he put it up on the board...
Your welcome...
Old Jan 31, 2002 | 03:19 PM
B2FiNiTY's Avatar
All praise Bbasso!
Old Jan 31, 2002 | 03:31 PM
fast[R]'s Avatar
That animation sais it all no more questions how it works good search
Old Feb 2, 2002 | 01:20 PM
Bbasso's Avatar
Default Re: this is how VTEC works (fast[R])
T H A N K Y O U!
I'll find some more info if its out there...
Old Feb 2, 2002 | 01:29 PM
StinkyTofu's Avatar
Cool animation
[Modified by SpecR_EK, 5:03 AM 1/29/2002]iVTEC is just VTEC + variable timing on intake cam (like VANOS)
more pictures:
I heard that the type-s has variable timing on both the intake and exhaust cam while the baseline only does it on the intake cam.
I'm still sorta confused...is iVtec basically like adjustable cam gears that adjust themselves to the correct timing to provide the most power at that certain rpm?
Old Feb 2, 2002 | 01:42 PM
Default Re: This is how VTEC works (B-18C1)
Not sure about the first one. But you're correct about the second one...
Old Feb 2, 2002 | 06:30 PM
arren123's Avatar
Default Re: this is how VTEC works (DontBother)
Either drain all your oil out or take off the VTEC Solenoid.
Old Feb 3, 2002 | 06:11 AM
BudMan's Avatar
how can i disable vtec on my car?? it's too noisy
What the hell are you even doing posting here??? I hope you are joking!
