injectors clips shaved..... soldering okay?
Old Apr 9, 2005 | 07:03 PM
chihuahuamanx's Avatar
Default injectors clips shaved..... soldering okay?
I recieved some corolla injectors from a HT member. I got out to the dyno and went to install them in the parking lot after the seller promised me that they would fit right in no problems. Well, to my dismay i found he shaved off any kind of little tab for the injector clips to hold on to. Now i need to find a way to get my car working. my option as far as I can see them are:
+ buy new injectors (doesnt sound very good to me)
+cut off the clips and hardwire/solder the wires to the injectors
+JB weld the clips to the injector, and then when i upgrade down the line remove and solder in OBD1 clips from my h23.
thanks, lemme know what u think!
Old Apr 9, 2005 | 08:15 PM
Kendall's Avatar
Zip ties maybe.
Old Apr 9, 2005 | 09:07 PM
Default Re: (Kendall)
yea i tried that while we were out there in the parking lot. Lawrence my tuner couldnt think of anything and suggested i get new injectors, but that soldering would work. New stuff if just sooo much bank. Im wayyyy over budget as it is, i just want this thing turbo'd its been three months of work and problems.
Old Apr 10, 2005 | 12:47 AM
Default Re: (chihuahuamanx)
bump
Old Apr 10, 2005 | 10:04 AM
Old Apr 10, 2005 | 02:03 PM
dfoxengr's Avatar
zip ties and elec tape.
Old Apr 10, 2005 | 02:25 PM
Default Re: (hybridvteceg)
i wish i could, but for the life of me i cant see any way to zip them down securly. why isnt anyone for solder and/or jbweld?
Old Apr 10, 2005 | 05:35 PM
Old Apr 11, 2005 | 07:24 PM
bump
Old Apr 11, 2005 | 09:58 PM
Kendall's Avatar
You could JB Weld the clips to the injectors, then cut all of the injector wires an inch or so above the clip and add in your own clips, this would be useful if you want to experiment with different types of injectors in the future also.
Old Apr 11, 2005 | 10:44 PM
yea i was thinking the same thing...... know anywhere to get good, reliable (in underhood temps) clips? wil radio hut have em?
Old Apr 12, 2005 | 08:35 AM
jweller's Avatar
why not just build up the little tab you need on the injectors with JB weld?
Old Apr 12, 2005 | 09:23 AM
Honda Hick's Avatar
Default Re: injectors clips shaved..... soldering okay? (chihuahuamanx)
What cc are these Corolla injectors? I'm sure you could find some DSM 450s for dirt cheap and not bother with this ghettoizing.
Old Apr 12, 2005 | 04:16 PM
Default Re: injectors clips shaved..... soldering okay? (Honda Hick)
theyre 440, but resistor box installs bug the crap outta me.
I could build up that tab w jbweld thats a really good idea, ill see if i can pull it off. any other ideas?
totsie7944
Apr 22, 2008 09:18 AM
infumis
Feb 8, 2007 03:46 PM
B18 CYA
Jun 23, 2004 04:15 PM
SpoolnG2
May 18, 2004 12:33 PM
ladysman
May 26, 2003 01:50 PM
