stuoid question
Old Apr 9, 2005 | 05:26 PM
fixxx's Avatar
Default stuoid question
ok guys this is probably gonna be one of the dumber questions but i had to ask
How do I take the the thing u roll the window down with off?
Old Apr 9, 2005 | 05:46 PM
none of the old poopy's Avatar
Default Re: stuoid question (fixxx)
dont pull it off, it'll break. you have take the screws out of the whole door panel, there's a little clip underneath this that holds the crank ("roll window down thing") on.
Old Apr 9, 2005 | 05:48 PM
eda6's Avatar
Default Re: stuoid question (All The New Rage)
If you talking about the handle...You can make a hook out of some wire and pull out the circlip behind the handle.
Old Apr 9, 2005 | 05:59 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
With a hook tool like this:
You pull out the gold colored clip that holds the crank:
Old Apr 9, 2005 | 06:06 PM
menappi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by All The New Rage &raquo;</TD></TR><TR><TD CLASS="quote">dont pull it off, it'll break. you have take the screws out of the whole door panel, there's a little clip underneath this that holds the crank ("roll window down thing") on.</TD></TR></TABLE>
mm no u dont have to take the screws or the door panel off. yeah u can use a hook thing or just pull the handle back a little and push it out with a flathead. to get it back in put the clip on the handle before it is in the notch and put it on the roller up thing, and then use a rag and slide it in between the panel and the roller and it will snap in.
Old Apr 9, 2005 | 06:26 PM
Mr_CRX's Avatar
Default Re: stuoid question (menappi)
... or to put it back on, you can just install it on the handle, and push the handle back onto the door. No need for a rag or any of that.
There's a bevel on the shaft coming out of the door panel, and it will spread the clip apart as you are pushing it on.
Old Apr 9, 2005 | 06:30 PM
88DXCRX's Avatar
You can actually just snap the clip back into place,
Position it correctly,and then give it a light smack..
The clip will expand and it will snap right back on..
Old Apr 9, 2005 | 07:59 PM
steronz's Avatar
Default Re: stuoid question (88DXCRX)
good info 88DXCRX, but i would suggest re-installing the clip 180 degrees from the way it is pictured above... it's easier to get out when you don't have the handle in the way.
Old Apr 9, 2005 | 08:01 PM
crxgator's Avatar
Default Re: stuoid question (steronz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steronz &raquo;</TD></TR><TR><TD CLASS="quote">good info 88DXCRX, but i would suggest re-installing the clip 180 degrees from the way it is pictured above... it's easier to get out when you don't have the handle in the way.</TD></TR></TABLE>
i have to disagree with you on that one...i find it easier the way phil has it...
the handle gives you a little leverage to move it out of the way, where the other way you dont have a way to move the handle out of the way per say...its hard to explain...
Old Apr 9, 2005 | 08:04 PM
RCautoworks's Avatar
The way Phil has it, is the way its suppose to be. Notice the door handle has a notch on it.
Old Apr 9, 2005 | 09:34 PM
steronz's Avatar
touche... never noticed the notch. i stand corrected.
Old Apr 9, 2005 | 09:36 PM
Default Re: (steronz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steronz &raquo;</TD></TR><TR><TD CLASS="quote">touche... never noticed the notch. i stand corrected.</TD></TR></TABLE>
Not touche, just like people to know the way Honda intended it , but Honda is not always right though
ddclutch
Honda Fit
Jul 4, 2006 11:06 PM
pompom
Feb 28, 2006 04:41 PM
okman16
26
Nov 9, 2003 12:48 PM
Mentat Ghola
Jan 11, 2003 04:47 PM
djpnj1
Sep 28, 2001 12:40 AM
