oil pressure...10psi at 600 rpm's and 40 psi at 3k rpms, normal?
Old Apr 9, 2005 | 05:04 PM
PA MATT's Avatar
Default oil pressure...10psi at 600 rpm's and 40 psi at 3k rpms, normal?
Today was the first warm day ive driven my car very far and my oil pressure seemed a little lower than usual. After warming up and coming to a stop sign my oil pressure would drop to 10 psi and was about 40psi in 5th gear at 3k rpm's...does this sound normal to everybody?Once in a while it would go just below the 10 psi mark. Is this a problem or is it normal?I recently changed my rear main seal, could that be the problem? also, im running 10w-30 durablend oil if that matters and only has about 1000 miles on it. I may try changing my oil to see what that does.
Old Apr 9, 2005 | 07:52 PM
mmuller's Avatar
Mad Scientist
Default Re: oil pressure...10psi at 600 rpm's and 40 psi at 3k rpms, normal? (PA MATT)
what oil filter are you using? pressure at 3k rpms should be more like 70psi
Old Apr 11, 2005 | 07:38 AM
Project X's Avatar
Seems a bit on the low side.
Idle (750 rpm) is about 15psi.
3000 rpm is about 55-60psi.
Old Apr 11, 2005 | 07:22 PM
PupaScoopa's Avatar
Default Re: (Project X)
I run 25psi at idle and 75 over 3k.
Old Apr 11, 2005 | 07:33 PM
LSVTEC 91 Civic's Avatar
Banned
In the colder months I'd get 24psi at idle, and now that its warming up I'm at around 19-21. Drain that durablend and switch to a German Castrol 0w-30, you can buy it at Autozone, and it says "Made in Germany" on back... GREAT oil.
Excusetobooost
Jun 9, 2020 01:19 PM
k20actr
Nov 26, 2013 07:13 PM
PA MATT
Apr 8, 2006 12:20 PM
PA MATT
Apr 11, 2005 11:29 AM
LSVTEC 91 Civic
May 25, 2004 05:56 PM
