tranny swap
Old Apr 9, 2005 | 03:58 PM
See Are Ex's Avatar
Default tranny swap
is there a way to change a cable tranny to hydralic , and what do you need to accomplish it
Old Apr 9, 2005 | 08:50 PM
vtec y0's Avatar
Default Re: tranny swap (crx_racer86)
I think Hasport sells a conversion kit
Old Apr 10, 2005 | 03:21 AM
See Are Ex's Avatar
thanks ill check it out
Old Apr 10, 2005 | 05:52 AM
VTECVillain's Avatar
Do you mean actually physically changing the mechanical cable operation on the tranny to hydraulic? If that's the case no you cannot do it. HASport sells a conversion kit to go from hydro to cable and vice versa but that's not how it works. Say you use a hydro tranny in an EF cable chassis, the HASport kit replaces the slave cylinder on the tranny with a cable operated mechanism. Basically it's converting the hydro tranny to cable operation. But to go the other way starting with a cable tranny, you can't change it to operate as a full hydro tranny.
Old Apr 10, 2005 | 01:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx_racer86 &raquo;</TD></TR><TR><TD CLASS="quote">no i have 92 civic hydralic and around here i cant find one out of 94-01 integra that i need but i can get all kinds of cable so hasport makes a conversion for this?</TD></TR></TABLE>
Yes it will allow you to run a cable B series tranny in your hydro car.
x92preludesix
Oct 24, 2021 05:40 AM
prelude182
Jul 16, 2009 06:54 PM
aggressivecivic
Mar 24, 2007 04:41 PM
88civichbz6
Jan 29, 2005 06:07 PM
