What OBD is 97 Accords?
Old Apr 9, 2005 | 02:06 PM
TeknoGroover's Avatar
Default What OBD is 97 Accords?
I know that OBD was changed in 1997, but the engines are the same as the 96 in the 97, but are the OBD? Under my hood it says OBDII Compliant. So does that mean it is OBDII? I wanna do an engine swap down the road, but I need to know what OBD I have. I have a 1997 Accord SE. Would it be better to get a F20b since it's OBDII? If I have OBDI, I would get a H22a.
Old Apr 9, 2005 | 02:12 PM
notoriousB's Avatar
Default Re: What OBD is 97 Accords? (TeknoGroover)
it's OBD2
Old Apr 9, 2005 | 02:29 PM
kniob's Avatar
Default Re: What OBD is 97 Accords? (notoriousB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB &raquo;</TD></TR><TR><TD CLASS="quote">it's OBD2</TD></TR></TABLE>
96 is when all hondas changed over to OBDII.
Old Apr 9, 2005 | 05:10 PM
solo2slocivic's Avatar
95 accord v-6's are obd2 also
Old Apr 10, 2005 | 01:26 PM
Schmitey's Avatar
Default Re: (solo2slocivic)
easiest way to tell is just to look at the plug
OBDII has maybe 12 pins on the top and like 10 on the bottom, its a distinctive shape
Old Apr 10, 2005 | 03:36 PM
H0ndaJunkie's Avatar
Your OBDII Port is located behind your Ash-tray. Just pull the whole ash-tray out, and you'll see it behind.
hari2m
Oct 17, 2014 03:33 PM
b20vtecturbe
Oct 19, 2009 08:23 PM
dc2leftovers
Nov 20, 2006 08:49 AM
TheBobFather
Oct 11, 2005 06:38 PM
kevs-ej1
Aug 22, 2005 04:48 PM
