Car doesn't idle
Old Apr 9, 2005 | 01:26 PM
nex-gensjdmteg's Avatar
Default Car doesn't idle
My car doesn't wan to idle at all for some reason i will start it and it will run for about five min. an It will idle between 850-1100 rpm and then i will drive for a while it a red light and it would idle it will rev up and down between 900-2100 rpm just up and down it just a started last weeks any advice?
B18c
Old Apr 9, 2005 | 06:06 PM
mugenracer's Avatar
Take off the IAC valve at the rear of the throttle body and clean it. 3 x 10mm bolts and it pops off.
Old Apr 10, 2005 | 07:23 AM
CleanShaven's Avatar
Default Re: (mugenracer)
take a grammar class while you're at it.
Old Apr 10, 2005 | 07:52 AM
330R's Avatar
Default Re: (CleanShaven)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CleanShaven &raquo;</TD></TR><TR><TD CLASS="quote">take a grammar class while you're at it.</TD></TR></TABLE>
Nice sig.. quite the attention *****, hmm?
Old Apr 10, 2005 | 08:19 AM
Default Re: (330R)
LOL. glad you can appreciate it. but to real theives, as im sure they wouldnt make it a point to advertise.
Old Apr 10, 2005 | 09:04 AM
Lucky-R's Avatar
Default Re: Car doesn't idle (nex-gensjdmteg)
if your IACV valve is broke, i have one for sale off a 98 itr motor for 50 shipped. otherwise, try spraying some carb cleaner around your intake mani area for possible leaks. have you touched anything on your motor or modded anything recently that might have contributed? we just got thru fixing a similar problem on my friend's motor and it is a Bitch! of a problem to deal with good luck.
oh, PM me for the valve, i have pics too.
Old Apr 19, 2005 | 05:47 PM
Default Re: Car doesn't idle (Lucky-R)
thanks man i will keep you mind
Eighty-Nyne
May 10, 2008 11:57 AM
LukieLuc
Sep 19, 2007 07:37 PM
redED9Si
Aug 21, 2005 06:58 PM
kb158
18
Jul 30, 2004 02:43 PM
ILOVEGIRLS
Mar 31, 2004 12:58 PM
