Tire or Wheel Bearing Roaring??
Old Apr 9, 2005 | 11:02 AM
nusdogg's Avatar
Default Tire or Wheel Bearing Roaring??
On my '94 Accord Ex Sedan, 5 speed manual. From the right rear side, while i was going about 40 and up MPH, It'll start to roar load, Loader than my Exhaust. You Can't even hear my exhaust, a little but i was wondering if anyone what it could be, Is it the Wheel Bearing Roar, or just the back tire, because those tires are worning out too. So please Help...
Old Apr 10, 2005 | 04:24 AM
SearchBeforeUPost!'s Avatar
Default Re: Tire or Wheel Bearing Roaring?? (nusdogg)
If you have bad tires, it very well could be those. Put the car in the air and wiggle the r/r tire and wheel to see if it has any play. If it does, then get a new hub/bearing assembly. If not, try rotating your tires and see if the noise changes or goes away. If it does, get new tires. Also check your brakes, it could be noise from those also.
Old Apr 10, 2005 | 03:51 PM
H0ndaJunkie's Avatar
You don't have to have excessive play (wiggle motion) on the wheel to mean a bad wheel bearing.
Raise the right rear with a jack and spin the tire as fast as you can. If you hear a roar, or grinding noise, it's probably a bad wheel bearing. If it does't make any discernable noise, you could have a broken belt in your tire. They get loud too.
Old Apr 10, 2005 | 04:36 PM
Default Re: (H0ndaJunkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H0ndaJunkie &raquo;</TD></TR><TR><TD CLASS="quote">You don't have to have excessive play (wiggle motion) on the wheel to mean a bad wheel bearing.
Thats true, you don't.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H0ndaJunkie &raquo;</TD></TR><TR><TD CLASS="quote">Raise the right rear with a jack and spin the tire as fast as you can. If you hear a roar, or grinding noise, it's probably a bad wheel bearing. </TD></TR></TABLE>
You can also do this and not hear anything at all because there is no weight on the wheel/tire. The bearing assy may still be bad.
Phil_46
Jun 11, 2013 09:16 PM
Tensa_Zangetsu
25
Nov 23, 2007 07:38 AM
jdl
Apr 9, 2007 06:55 AM
ricekiller1
May 2, 2006 08:39 AM
whagkangmakulet
Jul 14, 2004 05:06 PM
