right?
Old Apr 9, 2005 | 10:23 AM
budget's Avatar
Default right?
car was cold, took the radiator cap off put a funnel in the hole, turned on the car and put the heater on full blast.
squeezed top and bottom radiator hose, bubbles would rise to the top in the funnel and just "pop" or go back in, is that what its supposed to do? it started to get a lil low so i re-filled it to the top. did it till there was minimal to no bubbles left, it got to normal operating temp but the fan didnt turn on. both radiator hose's were both still cold/luke warm is that right?
Old Apr 9, 2005 | 10:31 AM
iam7head's Avatar
Default Re: right? (ratboy)
there's a air bubble bleed valve located near the themostat, use that instead of messing with the radiator.
loss the bleed valve until you see little bit of water starting to leak out, you do not have to take the whole thing off, the valve have a bore to bleed out air, then all you need to do is pour in coolant/water in the rad, keep doing that until you see a health size of coolant start running off the bleed valve(bubble's clear form the system), tighten the bleed valve and you're golden
xlusiveracer
30
Feb 10, 2017 11:49 AM
DFW
Jan 29, 2005 07:57 AM
dbailey
Nov 21, 2004 12:34 PM
b16racer23
Oct 13, 2004 12:56 PM
IloveNewt
Aug 6, 2004 09:19 AM
