h23 intake mani on a f22b head?
i read somewhere if it would be a direct fit. does it fit w/o and mods on it? how much of a difference is the h23 from the f22b intake mani? which car is the h23 off? thx for the help
I have one I am going to try soon to find out for myself, once and for all what the deal is... I removed the iab setup and ported the **** out of it while I have had some extra time to kill.
Need a prelude vtec tb still though before attempting to install... but if everything goes well I will be very intrested to see how the bigger plenum and longer runners work out, should make a bit more power up top.
the jdm f22b and h23 come with the same intake manifolds from the factory i believe...
pictures to point out:
f22b im
h23 im
both have the dual runner iab's from the factory...if there is a difference, it would be internal only...
f22b im
h23 im
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 »</TD></TR><TR><TD CLASS="quote">f22b1 does not though... and thats what I an going to be trying to mock it up on to see if it will fit.</TD></TR></TABLE>
oh, i was under the assumption you were using the jdm f22b....that intake manifold won't fit either of the usdm f22's...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick H »</TD></TR><TR><TD CLASS="quote">
oh, i was under the assumption you were using the jdm f22b....that intake manifold won't fit either of the usdm f22's...</TD></TR></TABLE>
It bolts up, but you would need to do some serious portmatching and figure out that whole IAB ****
breakyadown_89
May 2, 2009 11:15 AM
