WHEN I PRESS THE GAS ENGINE BOGS OUT?
Old Apr 9, 2005 | 08:41 AM
4door-r's Avatar
Default WHEN I PRESS THE GAS ENGINE BOGS OUT?
Just as it says. I just installed a72mm TB on a jdm type-r pistons in a gsr bottom end w/ a P&P head and jun 3's. I put everything back together right it idles ok but when I press the gas it bogged out, does anyone have any info. that will help me out.thanks
Old Apr 9, 2005 | 08:50 AM
Used2beAb16's Avatar
Default Re: WHEN I PRESS THE GAS ENGINE BOGS OUT? (4door-r)
did u try changing the fuel pressure?
Old Apr 9, 2005 | 09:06 AM
Default Re: WHEN I PRESS THE GAS ENGINE BOGS OUT? (Used2beAb16)
u know what else i was thinking maybe your tps isn't signaling properly or something. If you woulda put that controller in you could do a sensor check
Old Apr 10, 2005 | 12:30 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
did you check your ignition timing?
goat86
Apr 28, 2014 04:34 PM
TurboCivicR93
Oct 17, 2011 06:05 PM
Amed Irizarry
11
Jul 30, 2011 12:55 PM
BLU CIVIC
Sep 17, 2007 08:13 PM
TomM
Honda S2000
Jul 31, 2001 06:56 AM
